Author Topic: Oil leak possible Rocker gasget change on a 2.5 v6 cdx  (Read 1617 times)
sticky
« on: 03 March 2013, 10:56:52 »
I have just noticed a small drip of oil on the road now and again and after a real quick check by my garage they said it might be the rocker gasgets it seems to be coming from at the back of the engine but its difficult to say being so confind between the bulkhead . so I was wondering about the overal cost of this and the time it would take .
The garage guy said its a big job , so im assuming it'll be expensive then yes?
Also looking at some of the posts ppl have mentioned about making sure the breathers are cleaned yes ?I guess the garage would know this anyway wouldn't they.Can someone please help me with some info and advise me. Car is still running fine.
Thanks sticky .
Re: Oil leak possible Rocker gasget change on a 2.5 v6 cdx
« Reply #1 on: 03 March 2013, 11:04:59 »
..... I guess the garage would know this anyway wouldn't they. .....
In a word ....... NO  ;)
That's half the problem, garages fit pattern cover gaskets to cure oil leaks & don't sort the reason why they've failed in the first place. You then have two problems .... pattern gaskets that'll fail sooner rather than later & blocked breathers that pressurise the top end of the engine & force oil passed the pattern gaskets.  ::)
have a look at your breathers http://www.omegaowners.com/forum/index.php?topic=90653.0 If your have never been done in the life of your car, I suspect that'll tey'll need doing.  :y
« Last Edit: 03 March 2013, 11:07:11 by Andy B »
  • Auckland
    • Mazda MPV
« Reply #2 on: 03 March 2013, 11:12:20 »
Have a read of these two maintenance guides
Changing the V6 Camcover Gaskets
Cleaning the V6 Crankcase Breather Setup (just realised that Andy B has already directed you to this one  ::))
« Last Edit: 03 March 2013, 11:14:02 by Andy H »
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #3 on: 03 March 2013, 11:13:26 »
If its not a job you feel comfortable with, having looked at the guides, then try to make suitable arrangements with a member on here, or one of the mobile mechanics. It won't cost anywhere near the garage rates, and it'll be done right first time  :y
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #4 on: 03 March 2013, 11:14:38 »
Oh, and as stated earlier, only use genuine gaskets if you're going to do it yourself  :y
sticky
« Reply #5 on: 03 March 2013, 12:03:48 »
Ok thanks for all that guys
