Author Topic: Breather pipes  (Read 1251 times)
pauls
  • By the sea minehead
    • Bmw x3
Breather pipes
« on: 03 March 2013, 14:52:17 »
Can I blast carb cleaner down the two big pipes (y shaped thingy) to help keep it clean until I get chance to have it all cleaned properly. or will it cause issues if I dont disconect them first,
  • Auckland
    • Mazda MPV
Re: Breather pipes
« Reply #1 on: 03 March 2013, 15:49:04 »
If you do then the carb cleaner (and any crud it loosens) will go back down through the breather box and into the sump.
My choice would be to take them off the car and clean them.
Re: Breather pipes
« Reply #2 on: 03 March 2013, 16:02:23 »
Agreed take the hoses off to clean :y
Re: Breather pipes
« Reply #3 on: 03 March 2013, 19:21:47 »
Gently blowing through with compressed air is a good way of checking the pipes are clear, if blown both ways, into the sump, then through the top of the plenum.
But as said, its really not a good idea to flush all sorts of goop and gunk down into the crank cases. "might" block the oil pick up.
pauls
    • Bmw x3
Re: Breather pipes
« Reply #4 on: 03 March 2013, 19:34:19 »
Thanks chaps glad i asked before doing
