Author Topic: Slightly bent drivers door hinges? door not closing properly  (Read 1303 times)
SR-71Blackbird
  • Watford
    • 2.5TD Silver Auto Elite
Hi all,
I had the car on my ramps and there is a sturdy wooden fence next to where I park and when I rolled down the ramp after I was done I didn't close the drivers front door enough and it hit the thick wooden post when the car was trying to go backwards/downards.
So now when the door is swung shut the little catch on the door is about 0.5-1cm too low compared to the frame and it does close but not in a smooth action anymore!!! (Hate myself sometimes)
Can anyone suggest anything.
I have put some grease on the parts in contact and now it closes much easier but still I'd like to fix it if possible.
Any ideas?
Thanks guys
car5car
  • Florida USA
    • 01 Cadillac Catera
Re: Slightly bent drivers door hinges? door not closing properly
« Reply #1 on: 06 March 2013, 08:49:55 »
adjust hinges, check free play
01 CADILLAC CATERA 3.0 engine (Omega)
« Reply #2 on: 06 March 2013, 08:53:47 »
If only the hinges were adjustable .......   ::) They're welded to both the door & the A or B post  ;)
« Reply #3 on: 06 March 2013, 08:55:57 »
Any ideas?
Thanks guys
Depends which bit is bent. A long story short, but a relative drove the FIL LEFT foot accelerator disability car & got mixed up with his feet & caught the open door which reversing. He bent the A post.  :-\
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #4 on: 06 March 2013, 12:32:33 »
You might be able to realign the door with some wedges/blocks between the door and the pillar and some brute force. But you're even more likely to make it worse.
Take the car to a bodyshop, and see what they advise. They'll be used to dealing with such problems.
