Going VX part shopping Tomorrow
Started by Markie, 03 November 2006, 19:33:00
Markie
How about this for a shopping list .... although i may do it in two stages in an attempt to build rapport with my local parts dept and see if i can blag some discounts on the non tc parts.
V6 Vectra radiator (on tc)
V6 Vectra oil cooler/kit
climate control bulbs for MV6
Alloy wheel centre caps for facelift mv6 alloys
xxx litres of red coolant
20 litres of semi syn ( 4 for 3 tc offer)
header tank for vectra v6
as many coolant pipes/rad pipes for Vectra V6 as they can get!
Head Gasket Kit for V6 Vectra
thats gonna set me back oooooh £300.
Anyone had any success in getting a "trade price/cash price" for non tc parts ?
Markie
oh and i have all my part numbers apart from the climate control bulbs  - sure they were on here but searched and can find.... :(
I usually get trade price on non TC parts...
Taxi_Driver
Depends on your dealer......buying that amount of stuff i would think the dealer would give you trade price on non TC bits
sounds2k
climate control bulbs are p/n 9120630, change all 5.
Markie
Quoteclimate control bulbs are p/n 9120630, change all 5.
thanks for that - yep was gonna change em all theres only one left lit anyway  :o
this got delayed so Monday mornig for shopping  :y
sounds2k
well that's not too bad then, thought the info had come too late when I saw the date you started the thread!
the bulbs are 1.2 watts, should have a black base.
Markie
Quotewell that's not too bad then, thought the info had come too late when I saw the date you started the thread!
can never be too late with info or advice  :y :)
Make sure you get the right oil cooler kit......will look for the part number later but, its about 70-80+Vat for the cooler, plate, nuts and seals as a set, they may try to sell you the bits seperately
Plus, try elsewhere for the headgasket kit, Vaux are a bit pricey, the gasket shop (on ebay) for example sell a reasonable kit which has OEM gaskets in it (get vaux exhaust manifold gaskets).
Markie
QuoteMake sure you get the right oil cooler kit......will look for the part number later but, its about 70-80+Vat for the cooler, plate, nuts and seals as a set, they may try to sell you the bits seperately
NEVER a truer Mark  ;)
update....
can someone assist in confirming the correct part number for oil cooler?
"oil cooler " i say for y26se 2.6 sri v6 2002 last of old shape - they say " radiator - engine oil retail £226 plus vat circa £260 part number they have quoted is 90412391  ::) i have a print out in front of me now.... >:(
Not wanting to demolish my new relationship i have said id get back to them and thinking that they maybe dont know what there doing i am leaving the other major parts till i get this sorted - like radiator.
got the oil and stuff -cracking price for 20 litres.
Oh and they want £56 per gasket kit - so as mark said its ebay for them  :y
they dont have radiator in stock !
Markie
DAM so taken with the crazy oil cooler stuff i forgot my bulbs  >:(
I can post the part number tonight......
Markie
QuoteI can post the part number tonight......
would be excllent  :y
Right, the part number is:
93176626 - Radiator-Engine oil - £81 Retail+VAT (less trade price)
Now the first thing they will say is 'its not on the system' as it often does not come up on EPC, its actualy a TIS sourced number and can easily be found if they log into the Vx system. As such if is likely to be a next day delivery item.
Ow yes, you will also need:
4 off 11076852 - Oil pipe banjo to cooler metal washers.
4 off 12992647 - Seal rings (for coolant bridge)
Plus the grey coolant plate sealent (cant find the number for this), it comes in a small tube that goes into a sealent gun.
