Oil quality monitor ........
Started by I_want_an_Omega, 08 March 2013, 18:56:57
I_want_an_Omega
My Mk4 Mondeo is fitted with an oil quality monitor which will prompt for an early oil service if needed. I hope to never see it come on as I am changing the oil every 3,000 miles anyway.
My question is how exactly do these work? Is it a chage of an optical characteristic perhaps?
danzigfan
AFAIK this systems only calculate when the next oil change should be - depending on driving style...etc....
My opinion...you 'll get less than expected out of your car if relaying on that sensor. And that's the main purpose of this sensors
I_want_an_Omega
Quote from: danzigfan on 08 March 2013, 19:34:07
I am sorry - but I think you are wrong.  :-X
danzigfan
Maybe on some Merc you'll get sensor which electricaly tests conductivity of oil inside the sump but definately not in Ford or GM
scottambrose
Loads of audis chave had these for a while if you put the wrong oil in or it gets allmanky it wans you and puts it in limp mode
I_want_an_Omega
Quote from: danzigfan on 08 March 2013, 20:35:57
why not ?
scottambrose
Fords are quite complex nowadays they use low saps oil and i wouldnt be surprised if it did have sensors. Longlife oil was designed designed to work with how you drive. I get asked how ling does longlife oil last? It could20k it could be 3k depending how you drive and what journeys you do
They only have a pressure sensor, the oil life is calculated based on pressure and useage
