Have you ever used one of these and whats your view ??
Started by markspark, 09 March 2013, 13:04:02
markspark
http://www.ebay.co.uk/itm/12v-Volt-Solar-Panel-Power-Car-Camper-Motorhome-Caravan-Battery-Trickle-Charger-/360438335429?pt=UK_Gadgets&hash=item53ebcc87c5
Im thinking of hard wiring one of these to the omega as the car is left standing for weeks at a time and every time i want to go out in it the battery is flat, the car charges correctly and the battery is only 2 months old so i was thinking this may help keep it topped up whats your view??
the alarming man
yep i used to have one and it worked very well... :y
zirk
I got a couple from Maplin on there clearance sale some time back, think these were rated at 2 - 3 amps, cant honestly say I was impressed TBH, just dont think we have the right Sunshine in the UK, a friend of mine uses a BP one about the size of a Sun Roof on his Landy that works well.
My belief is if the car is going to be standing for weeks without a charging point nearby then diss the battery.
tigers_gonads
Yup  :y
Got that one in my shed trickle charging a bunch of 12 2.3 ah alarm system batterys.
Also got the next one up (2.4 ah iirc) perminently  conected up to the caravans battery during the closed season. It does a decient job of keeping it topped up during winter  :y
All bought from maplins  :)
markspark
would it work ok if i fixed it on the rear shelf in a saloon ??
Quote from: markspark on 09 March 2013, 15:51:25
If you ran dedicated wires to the battery it may work, but I'm sceptical that it will produce enough to be more than the drain of the alarm etc :-\
markspark
Quote from: Marks DTM Calib on 09 March 2013, 16:55:32
Battery buggerers!
Battery is fine its just the car being stood that kills it
if i use the car just once in a week i wouldnt have the problem but sometimes this cannot be done
i suppose i could just disconnect the battery when not in use but then i have to reconnect when i want to go out in car and that too could be a PITA if its raining.
zirk
Quote from: markspark on 09 March 2013, 17:07:13
Battery buggerers!
1 min Job, just diss the Neg and put some cardboard in place, a lot quicker than messing around jump starting IMHO.  ;)
Selseybill
Got the same one as pictured. Fixed to my caravan roof to keep the battery charged up in the winter months when am not using it.
TBH, in your situation I think I would fit an isolator switch :-\
