That's some difference!
Started by danzigfan, 10 March 2013, 12:32:43
danzigfan
I had some work to do on my omega this week and it all came out just perfect.
Throttle body now clean, ICV, cam cover replaced (again)
  and most important I replaced exhaust manifold yesterday...now that makes a difference!
I was afraid my 4-pot needs new hydraulic lifters after sounding like this for last few months when cold
http://youtube.com/watch?v=t_PBzTkrIQM
But then I figured out it could be leaking manifold's fault so I went for a cheaper solution first an it worked
http://youtube.com/watch?v=8WbcD-i6DK8
  She sounds beautiful now so I need to thanks to a member here Abiton for sending me exaust manifold all the way to where I live. Thank you again
danzigfan
The old manifold was already welded few years back it seems. Had a new crack anyway
Thing is why do they crack ? It was the same on the 2.0 vectra , they all cracked in the same place  >:(
Quote from: EMD on 10 March 2013, 15:30:46
Cast iron manifold firmly bolted to aluminium head. Differential thermal expansion means that something has to give. Whether it is the gasket or the casting that fails is down to luck really :(
78bex
I had the identical problem on my 2.2, I guess it was a design fault
I broke just one stud getting the old one off
danzigfan
On this, one screw was allready missing, bloody  previous mechanic  :-X
The 2.2 ones do seem prone to this.
Whilst the thermal aspect may have an impact, I don't think its the primary cause, as others don't suffer as bad. I'd guess either poor design, or poor casting.
It was well known the 2.0 vectra ones all cracked , i went to quite a few breakers and everyone was cracked in there as well  :( Someone did me a favour and wrote the car off so i didnt get round to fixing it  ;D
henryd
Quote from: TheBoy on 11 March 2013, 08:48:26
Or bad flow causing hotspots perhaps ???
other rides
Think fatherT's has this, but mine so far (luckily) has been ok  :-\
