What is it?
Started by MadMark73, 12 March 2013, 23:00:49
MadMark73
Hi all. I've noticed on the dash of my miggy a small something. It is positioned right in the middle almost where the dash meets the windscreen. It looks like a small solar panel.
What is it and should it be there?
2woody
is that the sus sensor ? gives solar load information to the aircon.
MadMark73
henryd
Quote from: MadMark73 on 12 March 2013, 23:32:43
What is it for?
The answer is in the first reply from 2woody :y
other rides
MadMark73
But I dont have air con. Only climate control.
I don't know what it does?
Could someone explain idiots language, please?
henryd
Quote from: MadMark73 on 12 March 2013, 23:37:09
If you have climate control you DO have aircon :y
other rides
MadMark73
So does it need to be regassed then?
I didn't think dual climate control was the same as air conditioning. If so where is the pump?
Quote from: henryd on 12 March 2013, 23:38:26
Climate is posh for air-con, it maintains temp, air-con only cools...... :y
If the sun is coming in to the car on the drivers side, then the sun sensor will make the climate control feed cooler air to the drivers side, and leave the pas side unaffected, as I understand it.
My ss has failed I'm told...
MadMark73
So is that what the auto button is for?
MadMark73
And should it be covered? Looks untidy as is?
Quote from: MadMark73 on 12 March 2013, 23:45:31
You set the temperature that you want and set Auto, I drive a Jeep and all set to Auto, looks after in car heat and screen de mist, same as our Mig, that is what 'Climate' is all about..... :y
Quote from: MadMark73 on 12 March 2013, 23:46:37
If you cover it up it won't be able to sense ::) ::)
