Author Topic: Paperclip test question...  (Read 998 times)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« on: 14 March 2013, 14:19:25 »
Hi all....
I have got a problem with misfiring/stuttering on the 2.5 V6. Happens when working up through the gears (auto). Once rolling at a speed, and in top, runs perfect.
Question/s ....can you do the paperclip test with engine running (I have only ever done it with engine off). If answer is yes, would you pick up more/better code readings with the engine running.
I assume you would insert the paperclip, then start the engine ;)
May seem a trivial question, but obviously I don't want to muck it up :y
Re: Paperclip test question...
« Reply #1 on: 14 March 2013, 17:03:55 »
You can, but the older ecu's don't pick up miss fire codes like the later drive by wires of the 2.6 and 3.2 with obd2 codes.
amba
  • Medway towns
    • German V6
« Reply #2 on: 14 March 2013, 17:16:28 »
Its better having engine running as you will normally "no rpm signal" as a code. :y
Missfire is normally on the HT side so probably wont store a code,unless the EML has been on.
Normal culprits are ..Plugs/Leads/Disspack ..in that order. :(
I spent yesterday replacing my N/S cam cover after it gave up,although was due a change with mileage, and had filled #2/4/6 plug well so worth having a look as my miss was similar to that described.
« Reply #3 on: 14 March 2013, 21:24:14 »
Normal culprits are ..Leaking Cam cover gaskets/Plugs/Leads/Disspack  :)
