Author Topic: Rear door,how to replace it.  (Read 1417 times)
ted_one
« on: 15 March 2013, 14:27:45 »
Sorry guys,it's another question...looks like I'm going to replace the o/s rear door,need to know how to,if any one can give me some pointers..again will be much apreciated. :y
Re: Rear door,how to replace it.
« Reply #1 on: 15 March 2013, 15:48:35 »
1. Pull the loom from the B post and un plug it. If electric, drop the window first.
2. Un bolt the check strap.
3. Support the door.
4. Drift the hinge pins out with summat suitable.
Can be done single handedly, but given how heavy the doors are, two people makes it alot easier :y
« Reply #2 on: 15 March 2013, 18:13:35 »
After unbolting check strap, close door, open driver`s door, drift both pins out, then remove rear door
the alarming man
  • medway kent
    • disco V8
« Reply #3 on: 15 March 2013, 20:58:27 »
i have done that on my own ONCE....never again...break me they are heavy :y
forgot my 3 weetabix that day
« Reply #4 on: 15 March 2013, 21:20:42 »
A doddle if you use my method ^^^^ :)
ted_one
« Reply #5 on: 15 March 2013, 23:53:27 »
 Many thanks to every one for the advice..all taken and will put to good use :y
