Author Topic: Ok, decision made! :-(  (Read 6802 times)
  • Auckland
    • Mazda MPV
Re: Ok, decision made! :-(
« Reply #15 on: 20 April 2013, 20:57:14 »
Details about SAI removal, please.
Pretty straight forward, remove bagpipes, remove SAI pipework leaving just the rubber hoses that connect the exhaust manifold sections and block those with a 15mm copper pipe end-stop inserted backwards and using the spring clip to secure it. The only other thing you have to block off is the vacuum hose to the solenoid valve then you can remove the pump from behind the front bumper too. Don't forget to remove fuse 29b from the engine bay fuse box - itt's the big red 50 amp one.
The 3.2 manifolds don't have SAI ports so you can save yourself a few plumbing fittings :y
dazzerM
  • Reading
  • Mokka 1.7CDTI, BMW 120D Shadow (It’s a work car)
    • Which ones closest
« Reply #16 on: 20 April 2013, 21:01:28 »
If you you want it to run cooler and not to fussed about the air con, you can remove the air con fans and the rest of the air con set up
You will need a non air con aux belt if you go down this route, so the cav v6 is the one to go for for   :y
Darren
« Reply #17 on: 20 April 2013, 21:03:09 »
Ok, today I made a very small start but....
When I took off the "Bagpipes" and found that some of the mounts were broken...
Also, on the back is a small square-ish box with a couple of vac pipes going into it...
Both pipe have been rubbing on the Aux belt one is worn but not holed the other is completely cut so I will replace them both..
Just out of interest, the cut pipe goes round the left side of the engine to a valve or something on the left back of the plenum, Any ideas what it all does???
Operates the rear multiram valve.Will cost you grunt. ;)
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
« Reply #18 on: 20 April 2013, 21:05:54 »
Andy, I have the 3.2 manifolds yet to be fitted! :-y
Dazzer, I do wanna keep the AC...
I hadn't notice it loose power so maybe it's been like it for a while.
Thanks Rob and Albitz...
« Last Edit: 20 April 2013, 21:08:50 by HockeyDave55 »
« Reply #19 on: 20 April 2013, 22:51:41 »
Or Omega 2 Lit with a/con - thats the correct length ;)
HockeyDave55
  • Milton Keynes
« Reply #20 on: 21 April 2013, 10:11:10 »
Why dose everyone think I'm ditching the AC?
I AM KEEPING THE AC!!! Not shouting!!!  :)
« Reply #21 on: 21 April 2013, 11:16:11 »
So,once youve ditched the AC................................................... :D ;D ;D ;D sorry,couldnt resist. :)
« Reply #22 on: 21 April 2013, 11:21:40 »
Aye thats what i did , saved a fair bit of weight as well  :P
HockeyDave55
  • Milton Keynes
« Reply #23 on: 21 April 2013, 15:12:58 »
Lol... You guys are funny, or being funny!!!
dazzerM
  • Reading
« Reply #24 on: 21 April 2013, 15:51:21 »
Seems win win to me, I wonder what Dave will do  :D :D ;D ;D
Darren
gstylebaby
  • stockport
« Reply #25 on: 21 April 2013, 16:04:29 »
I have a list i'm trying to work my way though as well mate so your not the only one lol.  Its going in the bodyshop for new rear arch's and the list goes on and on and on lol. :y
HockeyDave55
  • Milton Keynes
« Reply #26 on: 21 April 2013, 19:51:45 »
I'm going to take my time but I can tell you one thing I'm not going to do...
I'm not honing to rip out the AC!!! Lol
HockeyDave55
  • Milton Keynes
« Reply #27 on: 23 April 2013, 21:30:34 »
Right then...
Tonight, I thought I would tear down the front end... and this is what I found...
What a mess!!!
And the water pump...
Is it usual for the o-ring on the water pump to be split?
That wasn't the cause of the leak, it must've been leaking for ages, I did use some water...
Also, on the intake and vac system, I have ALOT of oil sitting about...
Is this a bad sign???
Any comments welcome as usual...
HockeyDave55
  • Milton Keynes
« Reply #28 on: 23 April 2013, 22:00:56 »
Aghhhhhhhhhhhhhhh! What size do the pics have to be??? 800x600???
anyway, here's a picture of the vac pips that's been cut by the taus belt...
