Tigra 1.4 Fuel Pump question
Started by zirk, 16 March 2013, 15:47:58
zirk
According to my local Factors a replacement in tank Pump for the Corsa B /Tigra will also fit an Omega?, cant see it myself, but if true might as well fit a Mig one to it?
Can anyone confirm or not. :y
ffcgary1
Mig fuel filters are outside the tank as is the corsa so could be the same, the filter on a corsa in the tank is a gauze type and not normally a service item as far as i am to belive
Jaguar XJ6
Are you buying just the pump, or the whole plastic assembly that it fits into?
I suspect that you are, as the electric pumps are pretty universal. And much cheaper than the assembly unless you're buying a LandRover one.
zirk
Just the pump or what ever works out easier, cheaper, not had a chance to rip it out and have a look yet but would have thought fairly easy just to pump unless its got some stupid plastic lugs holding it all together.
