Author Topic: clunking update  (Read 1150 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
clunking update
« on: 17 March 2013, 10:43:48 »
a while back I posted about a noise when turning left. I finally found out that a broken spring & also a wishbone rubber has play. the mechanics side of things I can fix but the camber set up I,m not so sure about. I don't know if there is a place near York that provides the service w.i.m does . plenty do a 4 wheel alignment but its not the same ,is it? :-\
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: clunking update
« Reply #1 on: 17 March 2013, 10:49:04 »
Nigel Langs in Bolton seems to be the preferred choice oop north.
http://www.nigellangsgarage.co.uk/page/Wheel-Alignment/
raywilb
    • Citroen C4 Cactus
Re: clunking update
« Reply #2 on: 17 March 2013, 10:58:14 »
  I,ll probably try to get over there . its camping out on the m62 I dread.
    • 530D M Sport, 330i Coupe
Re: clunking update
« Reply #3 on: 17 March 2013, 16:30:47 »
Nigel Langs gets a thumbs up from lots on here, I'm a bit further south and use Fleet Fit in Loughborough but I think that's a little far for you!
