VERY retarded question... but what sort of clip is this...
Started by Webby the Bear, 17 March 2013, 17:50:13
Webby the Bear
it's the only thing stopping my engie cover from coming off.... but how the fekdo you undo it  :-\
RIP Paul Lovejoy
Once use clips, they're used under the bonnet on a few Vauxhalls too.
You can usually un-clip it by prising the clasp bit apart with a small screw driver & reclip it together after with a pair of pliers. Or destroy it & use a proper Jublilee clip.  ;) ;)
Webby the Bear
Quote from: Andy B on 17 March 2013, 17:53:01
Once use clips, they're used under the bonnet on a few Vauxhalls too. You can usually un-clip it by prising the clasp bit apart with a small screw driver & reclip it together after with a pair of pliers.
i'll give that a go... cheers andy  :y :y :y
RIP Paul Lovejoy
Helfrauds sell a set of pliers to undo/refit them :y made by Laser iirc  :-\
STMO123
It's known a the 'effing nuisance' clip and is the reason a good mechanic always has a good supply of jubilee clips.
Aye i got some of those on the air pipes on the pug , quick twist with a screwdriver gets them off then into a box labelled useless stuff that mite come in handy one day  ::)
Webby the Bear
well i thought a pocket screwdriver in to the slot and a bit of prying would get it ''open''. no chance. going to cut it and replace with a jubilee  :y
RIP Paul Lovejoy
henryd
Quote from: Webby the Bear on 18 March 2013, 17:06:01
with the tool designed for them they are very easy to unclip/clip up :y
other rides
Quote from: henryd on 18 March 2013, 17:25:03
+1 :y
One of my more productive purchases  ;D
Murph
I usually just take a pair of side cutters to the 'sticky-uppy-boxy-bit' and they come off easily.
Its called something like Click-R. I have a tool here, was around £7 IIRC.  Same ones used on Omega breathers, assuming DLK hasn't been in there ;D
Can usually lever the clip/hook end off with a screw driver. Then a pair of pincer pliers to do them up. Very awkward though, and needs the proper tool.
