Author Topic: front shocks & springs  (Read 1225 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« on: 17 March 2013, 18:38:49 »
will the shocks & springs off a mv6 fit on a td? & do the job they are meant to do?  :y
Re: front shocks & springs
« Reply #1 on: 17 March 2013, 20:00:10 »
They will physically fit, but the TD is considerably heavier than any other engine in the omega range.
The spring and damper rates won't be man enough sadly.
raywilb
    • Citroen C4 Cactus
« Reply #2 on: 17 March 2013, 20:26:53 »
  thanks for input ,I did think they were about the same weight . I will have to find out the part No,s for the springs & shocks for the td    :y
    • 530D M Sport, 330i Coupe
« Reply #3 on: 18 March 2013, 13:59:11 »
Pretty sure front shocks and springs are the same across the range with the exception of MV6 LSC ones. Sure someone on here would be able to confirm this.
I have a set of Front Shocks and Springs off my Elite which haven't done many miles (I'll find out how many miles if you are interested).
