E36 316
Started by omega3000, 17 March 2013, 19:22:21
Good or bad  :-\ Or very bad ?
Selseybill
Watch out for plastic vanes on the water pump. They seem to break with age. Cheap to replace with the metal type but a sod to bled.
I've had a couple of 1.6/1.8 in the past both blew their head gaskets.
Underpowered, and the E36 isn't that nice unless it's an M3  :y.
Quote from: Selseybill on 17 March 2013, 19:49:45
Not a good sign then , best to look over the obvious then first for signs of gasket failure . Just browsing but there is one local to me that has been owned a good few years by the same owner . Mite take a look  :)
Selseybill
The straight 6 cylinder engines much better which you can get in the 3 series. Smoother and no head problems.
Any reason why head gaskets fail ?
Selseybill
water pump and overheating. Alloy head warps and will need a skim if overheated
Quote from: Selseybill on 17 March 2013, 20:12:22
First thing to check and replace then  ;) Need to get something straight though , which of the cars have the 6 cylinder in this model ? Is it the 2.0 and above ? Like del was saying i think the 1.6 will be under powered  :-\
zirk
The E36 I use to have was a 2.5TDSE great run around, good on fuel, will agree with the others if it has to be petrol then go for the 6 pot.
Quote from: EMD on 17 March 2013, 20:23:13
Anything 320i and above has a 6 Cylinder engine  :y.
Selseybill
1.6/1.8 a bit gutless 4cyl. Go for 2.0 6cyl upwards best. 2.3/2.5 more or less the same engine. 2.8 engine gets the same mpg as the 2.3/2.5. Diesel 2.5 TD pulls really well in the 3 series.
Ok thanks all , why so many of these cars located in london  ;D 2.5TD seems out my price range just now and not that many 2.0 . Have not searched for 2.8 but if it gets same mpg as 2.3 2.5 may as well gander .
EMD any omega with any engine is better than a 1.6 E36..  and avg maintenance costs are higher than the omega even with a small engine..
and most E36s now are for sale with a high cost behind..
Ok , i have a couple 328 in my watch list . Just testing the water to see how much they go for  :)
Quote from: EMD on 17 March 2013, 21:25:16
yeah.. 328 will be worth the cost..  :y
imo buy a manual ..
