Author Topic: Stop Sign  (Read 2253 times)
Stop Sign
« on: 17 March 2013, 19:23:18 »
Since when did the 'Stop' sign turn from a circle to an octagon in the UK?  :-[ ::) ::)
Re: Stop Sign
« Reply #1 on: 17 March 2013, 19:25:23 »
Around 1965 it would appear ....
http://en.wikipedia.org/wiki/Stop_sign
The former UK practice of using "Halt" or "Slow" at Major Road Ahead signs was discontinued in 1965 at the recommendation of the Worboys Committee.[14] Instead of replacing all the old "Halt" signs with the new Vienna Convention "Stop" sign, "Give Way" became the standard sign at UK priority junctions.
Although there is a reference to 1975 and the circles .... right down the bottom ...
« Last Edit: 17 March 2013, 19:28:14 by Entwood »
Re: Stop Sign
« Reply #2 on: 17 March 2013, 19:34:47 »
It was a question on the TV and I said round before they showed that answer, and when no 'circle' option was shown I thought they had made a mistake...... ::) ::) ::)
In my defence..............I have no defence, neither can I think of a Stop sign around here anyway...... :-X :-X
Re: Stop Sign
« Reply #3 on: 17 March 2013, 19:49:39 »
UK uses "Stop" signs very infrequently, far more common is the "Give Way" - Triangular sign
Re: Stop Sign
« Reply #4 on: 17 March 2013, 20:17:05 »
Yep, they are very rare down here ;)
Re: Stop Sign
« Reply #5 on: 17 March 2013, 20:35:50 »
Just about got my 'Tufty Badge' then.......... :D :D
Re: Stop Sign
« Reply #6 on: 17 March 2013, 23:15:16 »
I see 2 stop signs every time I go out... One at the end of my road and another 10 yards away at the end of the next road :y
But then these roads were originally USAF territory ::)
I_want_an_Omega
Re: Stop Sign
« Reply #7 on: 18 March 2013, 07:51:08 »
It's the only UK sign that's this shape - apparently so that you can see it's a stop sign from the opposite sign as well  ???
andrew-v8
Re: Stop Sign
« Reply #8 on: 18 March 2013, 13:34:40 »
Its also shaped like that so if its covered in snow you'll know what it means by the shape of it ;)
ozzycat
  • chudliegh knighton /devon
    • hyundia i30
Re: Stop Sign
« Reply #9 on: 18 March 2013, 19:39:13 »
all i know is the octagan replaced the roud stops
 sighn when mr entwood says it did and the give way one  became a triangle about the same time i allso no if you dont stop i bloodywell hurts :D :D :D :D
 if you think theres a well of ulimeted knowlage on this forum you can allways get a answer to your question :y :y :y :y :y
long live the magic tree
its good to be back
Page created in 0.021 seconds with 14 queries.
