Auto gears hard to shift, mainly in to reverse
Started by Webby the Bear, 20 March 2013, 17:59:02
There is quite a bit about those gearboxes failing and this quote
QuoteCould someone help me, my car is completely broken down and the garage is asking for £2400 as both Actuator and Control Unit are gone, do I've any way to get it fixed cheaper otherwise I'll have to scrap the car
:o
I would get it sent back to the dealers if you have anymore trouble with gear selection mate  :(
henryd
Quote from: Webby the Bear on 21 March 2013, 08:03:56
Quote from: henryd on 21 March 2013, 00:07:07
Quote from: Webby the Bear on 20 March 2013, 23:35:57
Quote from: martin42 on 20 March 2013, 23:34:03
is it possible to check fluid level or is it sealed for life
I've looked on the pan and theres no ''fill''. only a drain plug  ??? there appears to be no dipstick for it either. the Haynes manual only covers the manual transmission  ::)
When you go to college check autodata "service illustrations " :y
cheers henry... am I just being dumb and not seeing it then?  ::) ;D
No you're not,there's nowt there :-[
other rides
Webby the Bear
Quote from: henryd on 21 March 2013, 09:21:48
what would you do if you needed to drain and refill then?  :-\
RIP Paul Lovejoy
