Auto gears hard to shift, mainly in to reverse
Started by Webby the Bear, 20 March 2013, 17:59:02
Webby the Bear
Hi guys,
My new Ford.... shifts beautifully but today I noticed (just after I'd had my wheels balanced) that it was a bit hard and clunked in to reverse from 'P'. I put it down to being parked on an incline. But checked it a few times since and it's hit and miss as to whether it does it or not. Any ideas?
A quick google jobby and it seems the shift cable could be having some trouble, whether it needs replacing or lubing up. I was under the car yesterday having a nose around and saw the going in to the transmission (looked like the same-ish cable that the omega has for its throttle cable)... presuming this was the said shifter cable?
any help guys wud be great  :y
RIP Paul Lovejoy
Webby the Bear
Hi again guys, sorry not bumping... just want to know if what i'm about to do is correct  :)
this pic (pinched from google) is what I have going in to the transmission....
do I just clean the whole assembly with silicone spray and then cover it in grease? :)
RIP Paul Lovejoy
Go steady if cleaning the electrical switch. It may be sensitive to cleaning agents and need a cirtain grease. Ie white lithium grease. ..."may"
Worth a bit if research to avoid possibly expensive mistakes. :)
martin42
did you not have any warranty from the garage??
henryd
Quote from: martin42 on 20 March 2013, 22:42:26
+1,if it came from a garage take it back.
other rides
Webby the Bear
yeah it did come with 3k warranty. but theyre in southend. if its an easy fix i'd rather save myself the petrol and do it myself  :y
RIP Paul Lovejoy
martin42
but by doing that youve invalidated the warranty if it causes other problems,sometimes worth the petrol to get it sorted out by the garage
Quote from: martin42 on 20 March 2013, 23:18:06
+1  ;) ;)
Webby the Bear
Fair enough lads  :y its got 2 1/2 months still left on it so ill see how it goes  :y
out of interest do we think this is a likely shifter cable issue? as I mentioned it shifts nice whilst driving  :y
RIP Paul Lovejoy
martin42
is it possible to check fluid level or is it sealed for life
Webby the Bear
Quote from: martin42 on 20 March 2013, 23:34:03
I've looked on the pan and theres no ''fill''. only a drain plug  ??? there appears to be no dipstick for it either. the Haynes manual only covers the manual transmission  ::)
RIP Paul Lovejoy
henryd
Quote from: Webby the Bear on 20 March 2013, 23:35:57
When you go to college check autodata "service illustrations " :y
other rides
Webby the Bear
Quote from: henryd on 21 March 2013, 00:07:07
cheers henry... am I just being dumb and not seeing it then?  ::) ;D
RIP Paul Lovejoy
Don't be too concerned if it was on an incline - the mechanical gearbox lock may have been under strain, esp if the handbrake wasn't applied, or is a bit poor.
Webby the Bear
right. Apologies to all. Got in the car this mornin. I've simply not been pressing brake firm enough. When i put a bit more pressure on its fine. Lol just obviously getting used to it. Sorry to waste peoples time though
RIP Paul Lovejoy
