Lsd oil?
Started by checkers87, 20 March 2013, 21:09:37
checkers87
Hi guys im just changing the oil in my lsd and i was wondering if anyone could recommend the best stuff? ;D
zirk
Normal GM Diff oil topped with a LSD additive, some on here have used a ready mixed version but never tried that myself. Have a look in the OpieOil sticky in Parts section. Cant link it as on the mobile. Chris.
BOA90LS from Opie is apparently suitable too. Additive already included. :y
2woody
yes - its a "straight-90", AND NOT A NORMAL DIFF OIL - use this and it will be fatally poisoned.
zirk
Quote from: 2woody on 20 March 2013, 22:11:16
Dont really understand Woody, explain please?
2woody
if a normal gear oil is used ( i.e a "hypoid" oil ) then the diff plates instantly get coated with the hypoid agent, which stops them working. There is no way to repair them - its a chemical change
zirk
So are you saying dont use normal GM oil plus an additive then?
manolo
I installed a used diff and after replacement was OK about 10miles, and then began to vibrate in curves
whether the cause of the oil? I put 0.75l Opel oil for diff and 0.25 l additives for LSD (specification from Autodata)
I now have another LSD diff and I'm afraid to put the same oil again. If it can damage the diff plates?
