Electrical Diagnostics
Started by Webby the Bear, 22 March 2013, 13:25:19
Webby the Bear
Hi guys,
I'm currently looking at electrics in cars at college. I've got to say I don't totally understand it but I have a basic concept that, with your help, I can put a guide together as to how to diagnose something electrical that goes wrong.
It just so happens that my car has an issue that cropped up this morning  ::) that we can use to ''test the theory''.
But first we need to put the theory together.
SO
I gets in the car (the Ford  ::)) this morning and I pop it in reverse. When I do this the parking sensors should beep once (to tell me I've selected reverse) and then beep when I reverse near something. Simplez.
This morning however I put it in reverse and get a continuous beep.
So I'm thinking this is bad but also good as I really want to use the skills I'm learning in the real world. My guide is as follows. Please add stuff/tell me I'm wrong if you feel there's owt I've missed (but please, please, please remember it's me and put it in to baby language...literally!)  :y
1.) Simple things first. There are 4 sensors in the bumper. Makes sense to me to check for crap and debris on them.
2.) Next easiest thing... check the fuse and relays if this system has them. Obviously a visual is good but I believe the correct way is to check for continuity. Multimeter, touch the tabs, if it beeps the fuse is good.
3.) While we're there... check the socket that the relay/fuse go into. Again I think this is a continuity test but I could be wrong. Let me know if I am wrong. ;)
4.) Getting tricky... get to the connection behind the bumper or in the boot. My understanding is that this will be the place the connection is grounded (or earthed  :-X lol) so disconnect the connector, red lead in to each terminal, black lead to the chassis earth/ground and do a voltage test with the car on and gear stick in reverse (to check the voltage the system you're checking needs to obviously be on... if its not there'll be no voltage. simple but i was stupid enough to forget  :-[)
5.) continuity test each sensor... if multimeter doesnt beep then the sensor(s) fubard and needs replacing.
Now please remember i'm only learning and trying to help myself and others by putting this together..... so if i get it wrong definitely tell me where i've gone wrong.... but nicely  :y
As for the circuit itself I havent yet looked at a wiring diagram and I don't know how the actual system works but this is just based on what i've seen so far of systems.
any input you have would be awesome.
cheers guys  :y :y :y
RIP Paul Lovejoy
doz
Continues toan can be nothing more than a dirt on the senor. Always best to check the obvious before pulling the tools out
All systems are different .. but IF it was an Omega .. there is a test connection with an object that looks like a fuse - actually a 300ohm resistor, that when removed puts the system into diagnostic mode, this will, by a series of beeps, tell you which sensor is faulty. There may be similar provision on yours.
You need to research the specs of the system you are dealing with
Webby the Bear
Quote from: Entwood on 22 March 2013, 14:07:23
I'm thinking wiring diagram, right?  :y
Whilst yes i agree thats what i need to do to solve this individual fault, would you say as a general checking procedure its right?  :y
RIP Paul Lovejoy
Quote from: Webby the Bear on 22 March 2013, 15:51:31
IMHO No ... you need to research the system properly, manufacturers notes / TIS / handbooks etc etc .. a wiring diagram will NEVER give you diagnostic information.
eg .. the wiring diagram for the omega shows the test 300ohm fuse. Does it tell you the audible codes and what they mean ?? Nope .. it doesn't actually tell you what it does .. its just a 300 ohm resistor to the wiring diagram.
STMO123
Here's my list:
1.  Take it to someone who knows how to fix it.
2. Pay them.
Webby the Bear
Quote from: STEMO on 22 March 2013, 16:21:28
Here's my list:
2. Pay them.
Thanks for the useful input STE-HOMO  ::)
Entwood... thanks for the comments.
The reason I said about the wiring diagram was to locate the various wires that you may need to test. Having thought about it I suppose if the general logic is to first off test the part that's faulty then it makes sense to go straight to that and likie you say the bulletins would help...
e.g. a google search suggests people think its one particular sensor. so find the connection. probe and test it. that will show the condemned sensor.
Having said that wouldn't a wiring diagram be good to suss out which colour wire goes to which sensor (assuming you could get the diagram in the first place...it isn't in the Haynes).
RIP Paul Lovejoy
henryd
Quote from: Webby the Bear on 22 March 2013, 17:34:36
Here's my list:
2. Pay them.
Are the sensors standard or aftermarket ???
other rides
bigbadee
Quietly Confident
Elite 3.2 V6 (LPG)
Re: Electrical Diagnostics
« Reply #2 on: Today at 14:07:23 »
more infor please how do i read the bleeps just about to look at a new mig and the parking sensors dont seem to work thanks--------------------------------------------------------------------------------
Webby the Bear
Quote from: henryd on 22 March 2013, 17:41:33
Here's my list:
2. Pay them.
they are standard mate  :y
RIP Paul Lovejoy
Quote from: bigbadee on 22 March 2013, 18:07:37
Quietly Confident
Elite 3.2 V6 (LPG)
Have a good read here .. all explained .. :) you may have to go back into the thread a tad to find the description of where the test socket is  :)
http://oldsite.omegaowners.com/forum/YaBB.pl?num=1279621948/30#30
martin42
err its a ford fusion,best to read the manual webby,and see whats going on 1st
Webby the Bear
Quote from: martin42 on 22 March 2013, 18:36:23
thanks mate. as said this wasn't really a way of fixing this... just wanted to really discuss electrical diagnosis procedure as a generic thing  :y
RIP Paul Lovejoy
symes
If you read OP's thread -IN Morning_____--There was probably ice on sensors=leave it alone it will be fine :y
martin42
i dont get ice on my car lol  ;D ;D
