Author Topic: Cylinder misfire advice please  (Read 1150 times)
Banksy
  • Northumberland
    • 2003 2.6CD
« on: 23 March 2013, 12:13:28 »
Hi all,
I have a 2003 2.6 CD and the engine warning light came on, so I did the pedal test to get the fault codes.
They said:
P0300 Random/multiple cylinder misfire detected
P0306 Cylinder 6 Misfire Detected
As I know nothing about engines or mechanics in general, please could someone advise me about the actions to take to solve this ?
Thanks in advance
Phil
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Cylinder misfire advice please
« Reply #1 on: 23 March 2013, 12:17:29 »
Check for Oil / Water in the plug wells, then the Plugs themselves to start with.
pauls
  • By the sea minehead
    • Bmw x3
« Reply #2 on: 23 March 2013, 12:33:10 »
As said above if water it will be getting in from the windscreen scuttle check if foam is wet. if its oil its going to be cam covers. There is a good guide here to sort it you will more than likely need to change the coil pack but do checks first.
« Last Edit: 23 March 2013, 12:35:28 by pauls »
Banksy
  • Northumberland
    • 2003 2.6CD
« Reply #3 on: 23 March 2013, 16:11:27 »
Thanks a lot !
Regards
Phil
