volvo 240
Started by Toledodude1973, 23 March 2013, 16:51:51
Toledodude1973
Can somebody help with this one please, my friend parked up volvo 240 1993 when trying to re-start engine would not even turn over. Fitted fully charged battery dash lights come on but still no action, is it starter motor or something electrical thanks
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
kevinp58
Is it making a clicking noise if so then if it is a manual put in first gear rock it and see if it frees it up  :) make sure the ignition is turned off though  :y
Toledodude1973
Thanks for reply  Kevin its not even clicking, tried rocking it in gear no response
Broomies Mate
Will it bump/tow start?
Toledodude1973
yes broomie just bumped it in tescos car park and starts what does that put it down to
Broomies Mate
All other (primitive) electrics seem to be ok.  Ignition lights reported OK, Car runs ok when force started.
So;
Starter motor/solenoid would be my port of call.  Check all connections first.  Make sure all are solid and free from corrosion.  Then start replacing.
Toledodude1973
thank you i'll post the result next week when fixed hopefully cheers
kevinp58
Yup sounds like the starter.  :y
the alarming man
starters do get stuck on them,but then saying that the ignition barel can cause a fault like that,are there any codes stored on it....n.b it is NOT ob2 compliant... :y
best looking here first
http://www.volvoforums.org.uk/
Toledodude1973
thanks again for help cheers Paul
Keith ABS
  They do make good bangers them but not as good as Omegas do.
keith B
the alarming man
they make very capable cars and i hate too say it more comfortable than the omega...mine certainly had the same amount of toys :y
kevinp58
Quote from: the alarming man on 24 March 2013, 12:02:49
I had a 2.1 once and very comfy car and even with the 2.1 it didn't hang around
the alarming man
mine was a 2.3 estate...built like a tank...but it had air con,abs,power and heated seats,heated mirrors/window...went like a rocket :y
