Short journeys and omega.
Started by feeutfo, 25 March 2013, 18:10:12
Has a members car round recently. Bit of cam cover work. But in the process of stripping down there was copious amounts of water in the 135 bank inlet culminating in a pool of water in the bottom of the bag pipes. Defo water. Not coolant. Completely tasteless.
Noticed the oil filler cap plugged directly into the cam cover and obviously suspected short journeys which the owner confirmed.
Anything to be gained in covering the radiator partly with foil? Or any suggestions on maximising engine temp quickly for this member?
He did suffer miss fires on pot 5. 2.6 cdx. :)
If the thermostat is Ok then the radiator is doing nothing until it reaches working temperature anyway. Only real suggestion would be a coolant pre-heater, very regular oil changes and/or or a good motorway run every so often. Struggling to see how much water is getting into the intakes, though. Condensation from the breathers, you reckon?
Quote from: Kevin Wood on 25 March 2013, 18:46:59
Yes, condensation, and loads of it. Very pure water in some places, brown mayo in others. Evidence all the way from the breather box by pot 5, all the way to the puddle at he bottom of the bag pipes. Y shaped breather pipe full of brown goop, but only on one side.
There is now a problem with the top hat/D shaped seal on the Eco tech breather box to plenum. And the breather seals/o rings on the section that extends forward to the throttle body, as air is now leaking in after re assembly when the seal was seen to be perished/trapped from a previous re fit.
That might explained the uneven air flow per bank. ...it might also explain the the condensation in the first place. Period. Thing is the audible air leak wasn't audible before. There is now a rapidly decreasing air hiss once the engine is switched off. Clearly the water was evident prior to, and missfires evident via pedal trick. (But not maxiscan :-\  ::) )
Obvious one is to replace the seals and see if air flow through the breathers improves which it undoubtedly will. But the short journeys will remain. :)
Recomended replacing the relevant seals, but thought I nice chat on the subject wouldn't hurt in the mean time. :)
STMO123
Did you check that it was correctly shod? :-X
pauls
Top seal now replaced will keep an eye on breathers. Just to add this is only a problem in the cold weather.
Broomies Mate
May sound obvious, and bad advice at this time of year but keep the heater OFF for the first 10 minutes of the journey.
pauls
Quote from: Broomies Mate on 25 March 2013, 22:23:12
why explain please.
Would swapping the thermostat for a hotter one help, say a 95' one...
Quote from: pauls on 25 March 2013, 22:25:23
why explain please.
Draws less heat out of the coolant.
But bugger that IMO, Brrrrrrrrr ;D
The climate system on my 2.6 doesn't start blowing until it senses some heat in the coolant (I assume that is by design and the same for all late facelifts :-\ )
 ;D big mouse... Car has heated seats for a reason :P
Quote from: Andy H on 25 March 2013, 22:43:24
And PFL as well.
Trouble is, is its only used for very short journeys (less than 6 or 7 miles) the thing isn't really heating up enough to burn off condensation.
78bex
so the combustion blow-by gases contain the water moisture.?
Quote from: 78bex on 25 March 2013, 22:54:04
Yes. :y That's why exhausts steam (and eventually rot through).
