Author Topic: gaskets  (Read 1373 times)
mike clark
  • hull eastyorkshire
  • 2.5 v6 cdi
    • omega 2.5v6 cdi
gaskets
« on: 29 March 2013, 16:59:04 »
hi every one iam new to this were can i get rocker cover gaskets from please any were in hull or is ebay any good please reply thanks
Re: gaskets
« Reply #1 on: 29 March 2013, 17:01:38 »
Vx dealer mate - only fit genuine Vx or you could be changing them again in the near future.
You need gasket, o-rings (8 off) and black sealant - check with AndyC on here for good prices.
You also need to check and clean breathers as blocked breathers could be the cause :y
mike clark
  • 2.5 v6 cdi
    • omega 2.5v6 cdi
Re: gaskets
« Reply #2 on: 29 March 2013, 17:10:38 »
how to get in touch with andy c for gaskets
Re: gaskets
« Reply #3 on: 29 March 2013, 17:12:19 »
PM him ;)
Click here http://www.omegaowners.com/forum/index.php?action=profile;u=1488, then click on "send personal message" on left :y
« Last Edit: 29 March 2013, 17:13:57 by dbug »
Re: gaskets
« Reply #4 on: 29 March 2013, 17:33:56 »
OE gaskets on the face of are not cheap (around £80 all in IIRC) but cheaper in the long run because although pattern gaskets are cheap ... they don't last, & you end up doing them again.  ;)
mike clark
  • 2.5 v6 cdi
    • omega 2.5v6 cdi
Re: gaskets
« Reply #5 on: 29 March 2013, 17:37:19 »
so £80 for every thing wot about black stuff ?
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: gaskets
« Reply #6 on: 29 March 2013, 19:25:30 »
Yep, that should include the sealant. Don't forget to read the guides in the maintenance section, and ensure the breathers, etc are cleaned while you're doing the gaskets.  :y
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
Re: gaskets
« Reply #7 on: 30 March 2013, 09:44:57 »
I asked Andy for prices on these just the other day...
2 x 90511451  cam cover gaskets                   90511451 £35.84 each
16x 90411826  Cam cover o-rings                   90411826 £0.76 each
1 x 90485251  cam cover sealant                   90485251 £5.52 each
£89.36 + postage
You may want to double-check that is the correct sealant - I just reordered what I'd bought for the last one I did.
These are to do BOTH banks but it doesn't make sense just to do one.
There are other o-rings and stuff you may need when you're cleaning the breathers so check the guide first!
« Last Edit: 30 March 2013, 09:46:32 by sjc »
mike clark
  • 2.5 v6 cdi
    • omega 2.5v6 cdi
Re: gaskets
« Reply #8 on: 30 March 2013, 10:39:55 »
thanks
