Author Topic: Dead 3.2 Help...  (Read 4913 times)
Dead 3.2 Help...
« on: 31 March 2013, 22:38:06 »
Started with slight misfire quickly becoming intermittent throttle response.
Then no throttle response and idling very rough. Then cut out. Turns over and fires but cuts out after 10 seconds or so :-\
Half tank of fuel, just put £30 to be sure, as felt like running out even though gauge was just under a quarter. Waiting for AA, but pedal trick shows a bucket load of misfire codes and a couple of cat codes.
Car is due service/cambelt, but taking some comfort in the fact that it turns over, been quite tappetty the last few days though :-\
Re: Dead 3.2 Help...
« Reply #1 on: 31 March 2013, 22:50:15 »
Plug wells, duff coil pack?
« Reply #2 on: 31 March 2013, 22:53:50 »
All bone dry, nothing to indicate a dodgy coil pack, went from running perfectly to broken in about ten minutes :-\
« Reply #3 on: 31 March 2013, 22:55:23 »
what were the codes?  for one bank or 2?  Anything MAF related?  does unplugging the MAF make any difference?
« Reply #4 on: 31 March 2013, 22:55:55 »
Crank shaft sensor?  :-\ :-\
symes
  • oxford
    • R reg 940 volvo
« Reply #5 on: 31 March 2013, 22:56:39 »
maf/dbw throttle body :y or crank sensor
« Reply #6 on: 31 March 2013, 22:56:47 »
Checked plugs? I blew the electrode on one once, ran fine and in an instant changed to bag of spanners
« Reply #7 on: 31 March 2013, 22:56:49 »
Just read youve washed it....Is the air filter dry?
« Reply #8 on: 31 March 2013, 23:05:29 »
Maf unplugged no difference, filter dry, pipe from air filter dry and no different if removed. Codes 0420,0430, several 0300, 1 0305? And 0115. Car starts so not convinced about crank sensor :-\
« Reply #9 on: 31 March 2013, 23:07:27 »
Have you peered at the cambelt yet?  guess not? hoping youve not jumped teeth :(
« Reply #10 on: 31 March 2013, 23:09:27 »
So code wise, ignoring the old precat codes, we have a cylinder 5 miss, and a coolant temp code...
Wonder if it thinks your too hot / cold and is fueling to match?
« Reply #11 on: 31 March 2013, 23:09:54 »
have you a 'live data' capable code reader?
symes
  • oxford
    • R reg 940 volvo
« Reply #12 on: 31 March 2013, 23:17:37 »
0420=cat bank 1 left    0430 cat bank 2 right 300-random missfire  305-cyl no 5  0115-engine temp current malfunction :y
« Reply #13 on: 31 March 2013, 23:35:40 »
i do, well, someone elses.
« Reply #14 on: 31 March 2013, 23:48:26 »
Fuel pump perhaps?  :-\
0115 is an odd one though.
