Author Topic: airbags  (Read 7668 times)
greenman
  • greenock
Re: airbags
« Reply #15 on: 06 April 2013, 12:16:48 »
sorry!
elite spec with memory
that i enabled following "how to"
car is ,52 cd
Re: airbags
« Reply #16 on: 06 April 2013, 12:28:40 »
sorry!
car is ,52 cd
`52 plate should have child seat transponder in front passenger seat. When fitting pass seat did you connect the flat yellow rectangular plug from your loom?
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
Re: airbags
« Reply #17 on: 06 April 2013, 12:30:40 »
did i not say that way back
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
Re: airbags
« Reply #18 on: 06 April 2013, 12:32:21 »
Not quite ;) :y
adey2
Re: airbags
« Reply #19 on: 06 April 2013, 12:36:56 »
same system as in my elite, flashes a yellow warning light on on start up in light unit as goes through system test
Re: airbags
« Reply #20 on: 06 April 2013, 12:40:27 »
OP has the SRS (airbag) warning on dash. I reckon as his is a 2.2 CD spec the child SRS module in replacement Elite seat has been connected hence the warning. Just waiting for OP to respond to my Q
greenman
  • greenock
Re: airbags
« Reply #21 on: 06 April 2013, 13:26:02 »
I did connect yellow one
It wasn,t connected in previous seats
Re: airbags
« Reply #22 on: 06 April 2013, 13:33:25 »
Yellow one is for child seat transponder. Yours being a CD spec wouldn`t have had the SRS ECU configured for it hence the reason for it being not connected. Disconnect the yellow flat plug then get the light reset
greenman
  • greenock
Re: airbags
« Reply #23 on: 06 April 2013, 13:37:02 »
Thanks for that.
cannot get light reset till monday.
Once again thanks to all.
greenman
  • greenock
Re: airbags
« Reply #24 on: 06 April 2013, 16:36:03 »
Under the drivers seat there,s
a black connector labelled
lear 90565
749
E6
any idea what it,s for?
greenman
  • greenock
Re: airbags
« Reply #25 on: 17 April 2013, 20:23:42 »
Finally got code reader.
Showed 77,78.
cleared codes seems fine.
greenman
  • greenock
Re: airbags
« Reply #26 on: 19 April 2013, 09:51:01 »
It,s back on
code 77.driver side airbag circuit resistance too high
code 78    "       "        "         "           "            "    low
Had stayed off for 2 days.
