Author Topic: Battery light on and engine surging in tick over  (Read 2008 times)
wedge
  • North Tyneside
    • 2.6 Elite Estate '03 LPG
« on: 05 April 2013, 23:31:27 »
high all
yesterday my battery was totally flat and rashly i put it down to being old, mixed with the cold weather, so i replaced it today. now the battery light is on permenantly, also in tick over the engine revs surge
does anyone know the reason?
thanks in advance Martin   :)
remember,   "Shy Bairns Get Nowt"
Re: Battery light on and engine surging in tick over
« Reply #1 on: 06 April 2013, 00:27:33 »
I had exactly these symptoms when the alternator regulator failed. It charges for a second, then stops and repeats ad-infinitum. Each time it starts charging the revs drop due to the load.
Worth going through the starting and charging guide just to make sure, but might well be the regulator.
« Reply #2 on: 06 April 2013, 21:00:12 »
Yep dodgy alternator mate  ;)
wedge
  • North Tyneside
« Reply #3 on: 07 April 2013, 01:25:46 »
thanks for that  :)
the garage down the road has organized an auto electrician to come on monday, can anyone give me a rough estimate of how much i should pay for removing and fitting an alternator, also how much if the electrician can overhaul it.
(i'm a bit scared as they were once going to charge £1300 to do head gasket, when it turned out to be £24 HBV, so i'm armed with laptop and OOF maitenance guide of how to do it :-)
Martin
« Reply #4 on: 07 April 2013, 17:07:26 »
I got a refurbed alternator from Vx last year - cost £100 all in :y
Fitted it myself though so can't help with fitting costs.
Edit - assuming you have a V6 mate
« Reply #5 on: 07 April 2013, 17:16:52 »
It's probably the regulator - £20 for a new one.
Alternator change is probably an hour's work.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #6 on: 07 April 2013, 17:27:42 »
I bought a used alternator for my 2.5 V6 estate three years ago from a man in Girencester for £10 and popped it in. It's still working perfectly 28000 miles later.
wedge
  • North Tyneside
« Reply #7 on: 07 April 2013, 23:15:01 »
Yes it's a v6
Thanks to everyone for the help - a busy day sorting tomorrow then :-)
wedge
  • North Tyneside
« Reply #8 on: 10 April 2013, 11:41:44 »
hi all
refurbed alt was more than £150, with £45 extra you have to pay which is returned when you give your old alt in
using the maitenance guide on here i was going to replace the regulator inside the alt at £61 from drive vauxhall with the discount, but then they found they couldn't actually get hold of one
finally i contacted megavaux who had a box of 6 alt's for my car, one arrived this morning for £43 delivered. i'll now use the oof maintenance page and give the brushes a clean before it goes in.
thanks again for the advice  :)
« Reply #9 on: 10 April 2013, 20:46:52 »
hi all
Yep but my dealer gave me a "TC" price with extra charge (trusted me to pop old one back - which I did)
terry paget
    • 3 Astras 2 Vectra
« Reply #10 on: 10 April 2013, 21:27:06 »
Has anyone had bad experiences of Vx 'remanufactured' items? I bought a remanufactured starter for a petrol 2 litre Omega  five years ago and it failed after two years. I bought a replacement from a scrapyard on e-bay and it is still working after three years. They seem to fail in the solenoid section.  I have never had a failure on a V6.
