Author Topic: looks like im stuffed help advice  (Read 3089 times)
elitedave
  • harlow
    • elite 3.0L 1999
« on: 08 April 2013, 14:53:03 »
car is min face lift 3l elite t reg
just had a fun break down iv 40 miles from home
was traveling from luton to Harlow.
to girlfriends place
just coming in to Harlow and lost power steering bad on duel carriageway on an over take absolutely none at all
looked at dash and battery light is lit stop temp jumps sky hi
re steering iv already fixed abs unit once and relay behind glove box at different times
cam belt and water pump only done a few thousand ago
the car wont restart battery is dead was fine fully charged when i left
there's water spraying fast out of top hose after its cooled down iv manged to have a look
there is a small hole and crack on plastic end of radiator by top hose so it needs a new radiator
water and steam has sprayed over battery etc iv dried it all and checked all fuse under bonnet and in car
i boged  up hose and refilled water and jump  started it
just to get last 2 min drive to girl friends but it still appears to be trying to over heat with water
battery light is still on and abs and ignition is flickering and now power steering
engine seems OK bit ruff on tick over but im guessing or hoping that's due to battery being totally flat flat
iv got a laptop Chinese gizmo we cant talk about here but that's in luton
im going to have to pay if i get back to mine tomorrow as breakdown cover lapsed
now im not Shaw if its even worth towing home as got no idea whats up can change radiator in half an hour but with steering and other stuff now not got a clue
any one got any thorts ideas where to start
thanks guys
alank46
  • South Devon
    • 3L Elite Estate 1996
Re: looks like im stuffed help advice
« Reply #1 on: 08 April 2013, 15:23:02 »
Auxilary belt still there??
« Reply #2 on: 08 April 2013, 16:31:22 »
Water pump, power steering pump and alternator all run from the auxiliary belt so check that hasn't snapped
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #3 on: 08 April 2013, 16:32:21 »
sounds like your auxilary belt has parted company ;)
elitedave
  • harlow
    • elite 3.0L 1999
« Reply #4 on: 08 April 2013, 16:54:04 »
opps spot on how did i miss that im way stressed lost our dog last week had bad week
only problem is was on duel carriage way and i couldn't stop for a few hundred yard
but iv missed belt was bit shook up losing steering
after i refiled it i manged to drive it a bit about half a mile
and was getting very hot
what the chances of engine being stuffed or me getting away with it
 was running and sounding ok apart from lumpy tick over but battery's totally flat
i take you need a tentioner to change it as well
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #5 on: 08 April 2013, 16:56:34 »
nope tensioner is a 15mm bolt iirc, put spanner on and go to tighten and will allow belt to be flicked back on when replaced
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #6 on: 08 April 2013, 17:00:24 »
You will also need a 13mm small socket for the SAI bracket that needs temporarily removing to fit new belt :y
adey2
« Reply #7 on: 08 April 2013, 17:07:03 »
pia really as my missis left brentwood a hr back to come home, in boot spare belt and glove box spare tensioner pully just in case, if had helped you would of had her drop off to you sods law for you
« Reply #8 on: 08 April 2013, 17:21:00 »
Just make sure it's not a seized tensioner that has caused the belt to snap. In fact it's worth giving all the pulleys a spin just to make sure ;)
elitedave
  • harlow
    • elite 3.0L 1999
« Reply #9 on: 08 April 2013, 17:23:50 »
adey2 thanks mate that would have been a nivce jestor m8 i wish id have noticed early when was stoped and not refilled it and moved half a mile
OK plan is i got a mate with a tow truck see if i can get back tomorrow
as i got no tools here really
ill tape radiator with self amalgamating tape and some hot glue
hope that should hold before i pay out for new radiator to putt a new belt on and test it and see if its not cooked
ifs OK ill drop a new radiator in
any one got a idea what the chance of me having cooked it are.
elitedave
  • harlow
    • elite 3.0L 1999
« Reply #10 on: 08 April 2013, 17:25:20 »
thanks pete ill check it m8
pete what do you think the chances of it being cooked is
« Reply #11 on: 08 April 2013, 17:29:38 »
It's hard to say. The only way for sure is to put a new belt on it, try it and keep your fingers crossed :y
elitedave
  • harlow
    • elite 3.0L 1999
« Reply #12 on: 08 April 2013, 18:01:48 »
thanks m8 fingers crossed
« Reply #13 on: 08 April 2013, 18:35:46 »
Exact same happened to me , i was doing 75 ish coming back from scotland , smelt something burning but carried on , then all dash lights glowing like a scene out of CLOSE ENCOUNTERS and no power steering ::) with aux belt bouncing underneath the car  ;D RAC said your head gasket has blown  >:( I took the pulley off and re-greased it + new belt and was good again  :)
horsecow
  • Omagh
    • 2.2 dti cdx/3.2 elite
« Reply #14 on: 08 April 2013, 18:42:10 »
Hopefully you wont have done too much harm, be gentle if you do get her going again and give her a good service anyway just in case. Fingers crossed fella, keep us posted :y
Drive 'er like yer late for mass!!
