Pages: [1] 2 3  All   Go Down
Author Topic: divs guide to breathers  (Read 7000 times)
millwall
  • se london
  • no muff too tuff
    • accord type s
« on: 08 April 2013, 20:13:25 »
Well ive read the guides my cam covers have got a little leak even though they were done a year ago so im thinking the breathers werent done so being a bit of a div i have a couple of questions must i fully remove plenum to do the work is it only 2 pipes to clean or all 4 at the back of the black thing on the top will cleaning them ease of the leak until i can get them sorted as ive been shot in the hand so bit too painful to be getting too involved just at the moment :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: divs guide to breathers
« Reply #1 on: 08 April 2013, 20:18:19 »
Hey up Millwall  :y
I take the plenum off cos at the same time I clean the breather bridge and throttle body  :y
clean all 4 pipes of their crud, a bent paperclip to clean two breather holes in the breather box and a drill bit of about 6mm to clean out the big breather hole.
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #2 on: 08 April 2013, 20:19:00 »
.... plus also there's so much more room unless you have pipe cleaner fingers?  :-\ ;D :y
RIP Paul Lovejoy
millwall
  • se london
  • no muff too tuff
    • accord type s
« Reply #3 on: 08 April 2013, 20:26:56 »
Thanks webby will try it the propper way :y
« Reply #4 on: 09 April 2013, 11:14:06 »
2 cans of carb cleaner cleans the plenum breather box out well , no need to poke it unless its solid mayo  :o
Webby the Bear
  • Northampton
« Reply #5 on: 09 April 2013, 11:42:21 »
Thays why I use the screw driver as it picks up all the crap easily. i'm sure I read somewhere that you should try not to dump too much CC in the breather box  :-\
RIP Paul Lovejoy
« Reply #6 on: 09 April 2013, 12:02:23 »
I always take the box off , blow it through with cleaner then let it drain and dry out  :y
Webby the Bear
  • Northampton
« Reply #7 on: 09 April 2013, 12:16:46 »
Aha! That's where i'm goiung wrong... I never knew you could take it off  :-[
RIP Paul Lovejoy
« Reply #8 on: 09 April 2013, 12:34:24 »
Do you mean the black plastic across the plenum, or the big silver box at the back :-\
If you clean the Y shaped rubber pipe in place, the be sure to use a bucket load of carb cleaner, and change the engine oil before running the car, as that's where all the crud goes. The second largest pipe goes to a valve then to the vapour cannister in the o/s wheel arch. Too much carb cleaner down this knackers the valve, giving a smell of petrol fumes whilst running :'(
Best is to remove the pipes to clean them, then if the two holes on the breather box are blocked, remove that and clean separately, ideally soaking overnight. Needs resealing afterwards though :y
A quick squirt of WD40 through all the plastic and rubber bits before refitting is also a good idea :y iirc Entwood or Shackeng passed on that little tip :y
« Last Edit: 09 April 2013, 12:36:32 by ex taxi al »
Webby the Bear
  • Northampton
« Reply #9 on: 09 April 2013, 12:36:14 »
thought thatsa what we were talkin' about lol  :-\ :-\ ;D
RIP Paul Lovejoy
« Reply #10 on: 09 April 2013, 12:37:35 »
Just checking Mr Ted :y
« Reply #11 on: 09 April 2013, 12:58:56 »
Certainly not me ... I don't think I own a can of Satan's fluid ... and WD40 and plastic are not words that should be used in the same sentence unless you want a horrible sticky mess ..... :)
« Reply #12 on: 09 April 2013, 13:41:59 »
Silver box can be took off i think  :-\ didnt take mine off as it looked a pig to get at with a bad back  :-[ , black plastic breather on top of plenum i take off to clean  ;)
« Reply #13 on: 09 April 2013, 14:48:39 »
Apologies Nigel :-[ I thought it might have been either of you wiser peoples. It was at Guffers last bash, there was rugby on, and I've slept since then, so it could easily have been Guffers/TB/Lazydocker....
Or anyone else there for that matter ::)
The reason, as I recall it, was that carb cleaner 'dries' the rubber/plastics, causing them to go brittle :-\
scottambrose
« Reply #14 on: 09 April 2013, 17:11:36 »
how does the breather metal box come off
Pages: [1] 2 3  All   Go Up
