Author Topic: exhaust fumes from expansion tank  (Read 2081 times)
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« on: 08 April 2013, 21:37:34 »
is that a sure sign of hg failure and also water loss(no visable signs of leak) and temp rising and falling. if so I'm going to be busy the next day or so :'(
2.0 pfl if that helps
also do I have to replace head bolts what would happen if I didn't replace them?
dazzerM
  • Reading
  • Mokka 1.7CDTI, BMW 120D Shadow (It’s a work car)
    • Which ones closest
Re: exhaust fumes from expansion tank
« Reply #1 on: 08 April 2013, 22:33:59 »
It could be something as simple as an airlock, similar symptoms...
Out of interest have you changed/flushed the coolant recently  :-X
Darren
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #2 on: 08 April 2013, 22:36:37 »
Shouldn't you do a leak down test to confirm it's the HG?
RIP Paul Lovejoy
« Reply #3 on: 09 April 2013, 00:57:17 »
If you can smell exhaust fumes in your expansion tank, a compression test would confirm hg failure ;)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #4 on: 09 April 2013, 08:18:30 »
When you torque the bolts they stretch so if you reuse the old ones you are asking for trouble.
Plenty of tests you can do to confirm, a cold and warm leak-down test is a good start.  On the 2.0 a HG repair is pretty easy and can be done in a day (providing the head doesn't need a little skim)
plym ian
  • Plymouth, Devon
« Reply #5 on: 09 April 2013, 12:25:34 »
right went out to have a look today filled the expansion tank up and within 20mins on tick over it was almost empty no visable signs of a leak anywhere and I have a grey blue smoke from exhaust. I only changed hg less than 2 years ago but all signs lead to hg :(
Gaffers
« Reply #6 on: 09 April 2013, 12:46:49 »
Is there more moisture coming from the exhaust than usual? If so with the blue smoke coming from the exhaust I would suspect the HG.
plym ian
  • Plymouth, Devon
« Reply #7 on: 09 April 2013, 13:08:25 »
yes there is a small amount of water on floor :(
