Author Topic: v6 starter motor  (Read 1699 times)
ronomega
  • corby
    • mv6 03
v6 starter motor
« on: 09 April 2013, 18:05:10 »
Hi guys, i need a starter motor fof my mv6 auto. Everyone keeps asking the numbers of the starter, but i don,t know until it is removed and i can,t do it as have no tools. Any ideas please.
Big_Al
Re: v6 starter motor
« Reply #1 on: 09 April 2013, 18:42:52 »
Hi Ron
Is this starter to be replaced  issue a follow on from your "Battery Change " thread ?
If so do you know for sure that it is  the starter that is at fault?
Omega starters are usually pretty robust & don't fail very often at all IMO
There did not seem to be any outcome on your "battery Change " thread . . .
The guys on here will be of the utmost help to you  . . . but we need feedback from you regarding the problem .
That thread just seemed to end with no furthur response from you  :-\ :-\
Also it would help if you update your profile so that oofers know exactly which model & year you have . :y
Quite likely that someone on here would assist you if you added your location as well  :y
« Last Edit: 09 April 2013, 18:50:46 by Essex Big Al »
ronomega
  • corby
    • mv6 03
« Reply #2 on: 09 April 2013, 19:21:11 »
Sorry mate. It had the symptoms of cold weather. So changed the battery and now its clicking, not all the time though. Also i don,t really know how to use this site.
I have an mv6 2.6 03 plate.
« Reply #3 on: 09 April 2013, 19:32:27 »
In your "profile" where you`ve added the car you own, add your location also
Big_Al
« Reply #4 on: 09 April 2013, 19:59:00 »
The forum is easy to use , the experts on here can sort almost anything Omega  IMO, but they need info from you to be able to diagnose properly  & then  hopefully cure the problem  :y
OK lets start from the top  . . .    First question  . . Manual or auto box ?
If auto  . . check that the selector is in P or N      Car will only turn over to start  in those 2 positions but don't think you get a "click" if it is in one of the other positions  :-\
The original problem was that car had symptoms of a low  battery but had been ok up until that point ?
You then fitted a new battery & would not turn over at all .And  now  "its just clicking , not all the time though"
So sometimes it is doing nothing at all ?
Do you mean that you are getting a clicking  coming from the starter motor ?
And are absolutley sure it is the starter motor clicking ?
Reply to these questions & we can go on from there ?
Other more experienced members should now tag onto this thread & it should be able to get sorted  :y :y
« Last Edit: 09 April 2013, 20:03:09 by Essex Big Al »
« Reply #5 on: 09 April 2013, 20:10:17 »
If the clicking is coming from the starter motor, thats likely to be the solenoid not clicking over fully.  Check battery connections, engine earth strap before condemming starter motor ;)
Big_Al
« Reply #6 on: 09 April 2013, 20:24:17 »
Agreed . .  My opinion too :y :y
ronomega
  • corby
    • mv6 03
« Reply #7 on: 09 April 2013, 20:49:41 »
Thanx guy's. But it did not click until i hit the solenoid slightly due to access problembs and i have no ramps to lie underneath. If it is clicking is my starter ok? Or do i need a car sparky? What shall i do?
ronomega
  • corby
    • mv6 03
« Reply #8 on: 09 April 2013, 20:55:07 »
it is auto box as well.
Big_Al
« Reply #9 on: 09 April 2013, 20:58:32 »
Double check engine/starter earthing
Also put your location in your profile ( just the town )
 you never know someone from here may be right local to you & may assist   ;)
ronomega
  • corby
    • mv6 03
« Reply #10 on: 11 April 2013, 16:18:36 »
Cheers guy's. It is my starter as i earthed it on the block. I got one of here and when it comes i will let you all know. Thanx.
