Author Topic: vacume pipes off of break servo  (Read 1675 times)
elitedave
  • harlow
    • elite 3.0L 1999
« on: 12 April 2013, 05:07:54 »
you know the vacuums that come off the break servo ie the plastic bit with two vacuum outlets in between the two heat shrank pipes that  up by the bulkhead
one of the outlets as broke
is there any other way of fixing it or connecting it back with getting a new plastic bit and trying to heat shrink  it back on
if you do have get a new one anyone know the part number or what the hell you call it lol so i can look on ebay
if you do fit a new one what the eayest way of geting it on can warm heat shrink pipes a bit pull it off and heat it back with a heat gun etc
things the one with t pice that gos to heaters ie hbv other one is still connected but i presume with other broken off im loosing vacuum from broken one
« Last Edit: 12 April 2013, 05:18:25 by elitedave »
kcl
  • Finland
    • Volvo V60 D4 -14
Re: vacume pipes off of break servo
« Reply #1 on: 12 April 2013, 06:56:57 »
I once had the same with one 2,5 engined Omega and here's what I did: I blocked the original/broken connection and put generic t-piece to the hose from the other/non-broken connection. Works ok. Did purchase a new part to replace the broken one but never got that far...
« Reply #2 on: 12 April 2013, 08:30:04 »
Try one of the breakers on this site ;)
And remember, egay is full of 'tards.
« Reply #3 on: 12 April 2013, 13:42:57 »
The non return valve is cheaply and readily available from Vx :y
« Reply #4 on: 12 April 2013, 14:35:55 »
About £10/£11 IIRC The plastic gets very brittle ... hence snapping in the first place, so would be wary of A N Other  :y
And then 15 mins to soften the vacuum pipe up enough to remove the old valve & fit the new one.
elitedave
  • harlow
    • elite 3.0L 1999
« Reply #5 on: 12 April 2013, 15:01:47 »
Thanks guys but it a bit academic now looks like head tasked has gone and maybe top end damage :'(
« Reply #6 on: 12 April 2013, 15:09:48 »
If you meant head gasket, I'd be surprised. It's very, very rare for them to fail on a V6.
What are the symptoms?
« Reply #7 on: 12 April 2013, 15:58:23 »
As Kevin Wood says, HGF on a V6 is rare, bar some 1998 that leak coolant to outside the block.  When I say rare, I mean incredibly rare. Unheard of type rare ;)
So, symptoms?
elitedave
  • harlow
    • elite 3.0L 1999
« Reply #8 on: 12 April 2013, 16:53:59 »
i stoped prity quick at the time m8
but i missed the belt it wa dark missed as radiator was leeking i assumed it was all over fuse and batt from crack on radiator plastic at top hose that why batt was dead
it cooled i refilled and drove one mile as I was in middle of no where in harlow in the3 dark
called a tow and towed back to luton
fixed tentioner pulley that seized put in new rad and aux belt
i just brimed coolent header tank its lost about 3liters in 2 miles home
as i had it towed to my mothers as tow truck couldent get up mu drive with it and power steering was out
but its down on power as well or seems to be
im tempted to pull it off and have a look under there but tonight im not a happy camper
mrs is mental ill  and im a fulltime carer for her and were absolutely stuffed for transport at the moment
iv got a poped disk and screwed back and nearest bus stop is a mile or more away
cant get her in a tax as she delutional and think all the taxi drivers are following her
she is  bi polar with paranoid delusions
spent a fortune on vet bills two weeks ago when we lose our dog
feel like getting a violin out
iv got a bike but mrs wont get on back and im running out of cash fast
i have got a new oil cooler and gasket in cupboard i think
