Pages: [1] 2 3  All   Go Down
Author Topic: Suspected head gasket failed 3l v6  (Read 6500 times)
elitedave
  • harlow
    • elite 3.0L 1999
« on: 12 April 2013, 15:00:17 »
Re looks like I'm stuffed Thead and seized tension pulley and aux belt and leaking radiator
Just got it all back together after putting in new radiator pulley and belt
Start and seems to be running ok on all cylinders and don't seem to be running too bad
temp seems stable to
But coolest is pussing out under car and trickerling off sump
It not coming from anywhere near what's been touch ie up frount by radiator
And steam from under back of plenuim thing
Hbv is fine checked so is heater hoses only done heat matrix few weeks back
Is it worth look anywhere else for a leak or do you guys thing it is defiantly the head gasket
As if it a top end rebuild I'd beyond me and I'm running out of cash fast
So I'm guessing it the head gasket
« Last Edit: 12 April 2013, 15:59:22 by TheFatShadow »
amba
  • Medway towns
    • German V6
Re: Suspected head gasket failed 3l v6
« Reply #1 on: 12 April 2013, 15:22:20 »
Take the plenum and inlet manifold off followed by the lower sandwich plate to have a really good look at oil cooler plate/thermostat and coolant bridge area.
They are all very strong possible areas that can leak and give the very symptoms you are describing
elitedave
  • harlow
    • elite 3.0L 1999
« Reply #2 on: 12 April 2013, 15:27:13 »
Could a overhead from a failed aux belt cause that
« Reply #3 on: 12 April 2013, 15:29:40 »
Worth checking the oil cooler plate & coolant bridge area, not unknown for one of the pipes at the back to split and pish coolant all over the place.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 12 April 2013, 15:39:03 »
Was the Car / Engine being used after the Aux Belt problem, if so, how long for?
elitedave
  • harlow
    • elite 3.0L 1999
« Reply #5 on: 12 April 2013, 15:54:00 »
Was on duke charge way when it went had to drive to ther was a turn off few hundred yards
Where radiator was pissing out all over electrics and it was dar I cout not see belt and wrongly asuned power steering outage was due to water from lradiaitor leak
So re filled when cooled and drive one mile after that it was towed
JayMV6
  • Reading
« Reply #6 on: 12 April 2013, 15:58:47 »
Could it be just excess water thats sat in between the heads from when you lost water. when u first broke down was engine covered in water?x
« Reply #7 on: 12 April 2013, 16:01:48 »
Plenum off, along with inlets, so you can see right into the V.
Join or block the 2 pipes that you removed from throttle body to remove plenum.
Pressurise the coolant to about 8PSI (blowing hard into one of the pipes above will work) - coolant leak will be obvious.
elitedave
  • harlow
    • elite 3.0L 1999
« Reply #8 on: 12 April 2013, 16:30:21 »
car was at my mothers place where i had it towed to from essex
i justed brimed header tank and drove home to my place couple of miles away temp stayed in right rang and lost about 3 liters on way took it back too mine to get tools back here and car
but its well down on power
im well not happy as aint got money foer  another car and are in a mess for transport now
symes
  • oxford
    • R reg 940 volvo
« Reply #9 on: 12 April 2013, 17:42:02 »
if you down on power and do you have lots of exhaust smoke-then you likely hhave killed h/gaskets-is oil on dipstick coffee colored ??? When i did my old engine it was smoking like a ******* and no power/oil filler full of white gunge and dipstick was saying I had 3/4 level coffee :'( :'( :'( sorry mate reckon you done h/gaskets IMHO
« Reply #10 on: 12 April 2013, 17:50:04 »
Extreme overheating is a worry, but do tests I suggested to locate leak.
If HG has failed due to overheat, inspect heads very closely
zirk
  • Epping Forest
« Reply #11 on: 12 April 2013, 17:54:15 »
Hmm,Im 50 50 on this one,it doesn't take much to do a HG on the V6 without the Water Pump running, I know from experience when the Ex killed off one of my Plods after driving it for 5 mins when the water pump pulley threw the Aux belt!
Does it sound completely normal when you turn the engine on the starter?.
Im up the road from you if you want a second opinion, might not be the right one, but 2 heads are better than one and all that. ;)
symes
  • oxford
    • R reg 940 volvo
« Reply #12 on: 12 April 2013, 18:28:21 »
Lets face it people-any engine especially v6 mig will do H/G's in if no coolant-no brainer really-so but its true-I had that a few weeks ago and was quicker/cheaper to change engine on mine(243000 miles) anyway
elitedave
  • harlow
    • elite 3.0L 1999
« Reply #13 on: 12 April 2013, 22:12:24 »
its kind of you m8 but it i luton now not Harlow would have loved a second opinion
girlfriend is in Harlow i live in luton m8
the belt pop`ed on the a414 just before  east wick roundabout and want really any where to stop but east wick turn off it was only two roundabout up that i drove after refilling to the
was going to Harlow station roundabout as she lives just of the station roundabout
 TheFatShadow tomorrow im going to pull it all off and look under there at oil cooler and that
thing there aint no smoke there was at first but it wa pissing down thing was just warter in end of pipe after a min no smoke but now thers no smoke to speek of
i think it probably is head but there a hell of alot of coolant pissing out form out side rather than inside of engine
but im going to try anyway with crossed fingers as i would like to keep for now if i could
it got to be worth a try if its not leaking there
and it head im going to cut my losss and move on
and scrap it as i cant break it as no where to keep it off road and break it
unless any one wants to make an offer for spares or repair
back arches were due to be done as starting to rust but its only got 105k on it iv had it since 40k suspensions been done done heat matrix just had new front wishbones for all German parts 4 mouths ago
just had new back box and two new mid boxs and pipes
one of the guys of the forum done my water pump and cam belt kit not that long ago for me
and now a new radiator and aux belt and pulley
crank sensor been done since i had and i done the abs ecu already
only thing wrougn with other than this was driver heated seat element dead couple of l bulbs need changing back arches now need doing and a small rust bubble on bottom of back door
and i was going to spray front splitter as girlfriend court it on a curb
« Reply #14 on: 13 April 2013, 16:19:26 »
With plenum and inlet manifold off, look carefully around coolant bridge.  If its p*ssing out likely to be rubber hose from coolant bridge to HBV (the "curly" one).  Flex it and look for holes around where its clamped to coolant bridge.  Also check its not leaking from the coolant bridge seals, although wouldn't expect it to p*ss out fron here unless they are completely gone.
Also check oil cooler plate and thermostat housing while stripped.
Pages: [1] 2 3  All   Go Up
