landrover dico help
Started by paul.lovejoy, 18 April 2013, 18:25:23
paul.lovejoy
may suprise wifey she would love a disco and having owned several fourtuatley both new so i know nothing about problems with them as they get older.
i was hoping to get a td5 up to a bout 3K value is there anything to really look out for and avoid etc oh yes and it would have to be an auto unfourtunatley. or do you think its a bad idea for that sort of money,  wifey also likes the hyundia santa fee which i have been told is quite sound ???
any advice please thanks
the alarming man
Quote from: paul.lovejoy on 18 April 2013, 18:25:23
paul just like an omega...timing belt change on diesels...petrol as a chain...oh and rust a d2 can rust and once you have checked for rust check again....they rust better than a disco 1
paul.lovejoy
Quote from: Albitz on 18 April 2013, 18:33:51
Whats a Dico ?  :-\ ::) :P :D ;D
its what i would drive you should know me by now ;D ;D ;D
paul.lovejoy
henryd
Quote from: the alarming man on 18 April 2013, 18:40:51
They do indeed rust but not in the same way as the older Disco's,its the rear end of the chassis legs that mainly rot out.The body and boot floors especially seem much better protected,My Disco 2 is a 99 model and the body is totally rot free,I have treated the chassis as best I can and that's ok as well at the moment but I know it will go eventually :'(
other rides
doz
Looked at loads until I decided to buy a P38. I really suggest you drive the T5 with the slushbox. It's a bit slow not quite as bad the old 6 cylinder BMW veg burner. Honestly for the MPG difference don't discount a V8 on gas. Decoding Landy's is a pain. Disco 1's need a completely different system. (ECU mate is the cheapest). Disco 2's will let you use a basic OBD reader but if you want to go deeper and look at the other systems like brakes ABS your need a different system again. So you end up looking at Hawkeye or Black box solutions. Once you get your head round that it's a simple enough system. They have problems like every other car maker however parts are cheap. Worth checking the sun roofs don't leak, the family get a cob on when their head gets wet!!!!
henryd
Quote from: doz on 18 April 2013, 19:17:38
Tell me about it,one of my first jobs was headliner out and sunroofs out and re-bonded :-X
other rides
Crazycarzowner
Apart from the usual body rot and chassis as has been said before :-
Check Chassis and box sections for rust and accident repairs
Check for Leaking sunroofs
Check for Water getting in above the rear door.
Check Air suspension, Is it sitting level?
Does the air compressor come on at start-up?
Check for leaks at the bottom of the suspension air bags
Check for Smoke, Look for blue oil smoke, black diesel smoke (overfueling), heavy black diesel smoke (failing turbocharger) or white smoke on starting (water in the bores)
check steering (bushes tend to wear out)
Check for Coolant leaks, Td5 water pumps can leak, causing coolant level to drop, then overheating occurs....
Check ACE (Active Cornering Enhancement) pipes for corrosion. Can be seen behind the off-side front wheel (very costly to put right)
Check all warning lights including abs/hdc/tc lights on the dash come on AND EXTINGUISH once started, if not then there's  hub sensor problems
paul.lovejoy
better write this lot down..cheers chaps :y
henryd
Quote from: Jasonm on 18 April 2013, 19:27:03
And don't forget the really shit fuel economy,oh hang on,thats just mine being a V8 :-X
other rides
doz
They are super crap on Petrol. Only way is LPG and then don't expect more 12-14 MPG (3.9 lump later ones maybe better) My 4.6 P38 Rangy slaughters my 3.9 disco in the MPG stakes. I got 20 MPG coming back from Exmoor on petrol. That was sticking to 70 with some silliness coming out of the roundabouts. For a big car it does get down the road quickly. Luckily I now have the LPG kit up and running so hopefully 17 MPG on gas should be doable.
henryd
Quote from: doz on 18 April 2013, 21:09:58
Mines manual and on petrol and does 16-17 around locally doing school run etc,only does about 100 miles a week so not too bothered really,got the Signum for the longer faster runs :y
other rides
paul.lovejoy
doz
Quote from: paul.lovejoy on 18 April 2013, 21:21:16
but they do sound good :y :y
Oh yes and blipping the throttle at traffic lights is compulsory to get that body rock going  ;)
