Author Topic: Cruise control  (Read 2057 times)
astroblaster
  • Chesterfield
    • 2.6 petrol auto cdx
Cruise control
« on: 21 April 2013, 14:51:14 »
Hi is there a fuse for the cruise control cause mine has suddenly stopped working.
Many thanx John
Do it today cause tomorrow it might be Illegal
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Re: Cruise control
« Reply #1 on: 21 April 2013, 14:55:23 »
fuse number 2  15 amp  also covers brake lamps,hazard warning lights & fog tail lamp  hth  :y
Taxi_Driver
Re: Cruise control
« Reply #2 on: 21 April 2013, 18:11:51 »
Check you dont have a wire hanging loose by the brake/clutch pedal area, it not uncommon for feet to disturb wiring in this area......and will stop cruise from working  :)
astroblaster
  • Chesterfield
Re: Cruise control
« Reply #3 on: 25 April 2013, 15:50:52 »
thanx but the lights work fine so don't think its the fuse, and I cant see any wires hanging down.
Any other ideas
Thanx John
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: Cruise control
« Reply #4 on: 25 April 2013, 15:58:38 »
could the stalk be at fault here?
astroblaster
  • Chesterfield
Re: Cruise control
« Reply #5 on: 26 April 2013, 16:20:11 »
don't know how can I check
Re: Cruise control
« Reply #6 on: 26 April 2013, 16:40:26 »
Depending on the engine fitted, has any work been done under the bonnet which might have disturbed any connections on the throttle actuator :-\
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
Re: Cruise control
« Reply #7 on: 26 April 2013, 22:08:35 »
Would be my guess too - they're guilty of failing.
To test: remove the steering column shroud and look for a little separate wiring lead with 4 cables in it coming out of the stalk.  Disconnect it at the harness plug and use a multi-meter on "diode" setting.
Usual fault is the wires break where they flex with the movement of the stalk.
Simon.rose1
  • Walsall
    • Omega 2.5v6 cdx
Re: Cruise control
« Reply #8 on: 28 April 2013, 08:49:02 »
Check the clutch switch hasn't been moved as on my vectra the bracket had moved and needed bending back to make the switch work properly
