Author Topic: door trim removal  (Read 1714 times)
MV6Danny
  • Swindon, Wiltshire
  • Driving at the speed of light
    • 99 irmscher mv6 3l Manual
door trim removal
« on: 21 April 2013, 22:21:46 »
Hi does anyone know how to remove the outer door trim that sits below the window? I am talking about the black plastic or rubber part. Also the two rear trims by the back window just above the boot lid on a saloon? Thanks
Back in the MV6 again now
flyer 0712
Re: door trim removal
« Reply #1 on: 21 April 2013, 22:24:13 »
may need to know what model and year.. :-\ :-\
« Reply #2 on: 21 April 2013, 22:25:48 »
Look at ops profile - 99 irmscher mv6 3l Manual ;)
Assumng pre f/l look here - http://www.omegaowners.com/forum/index.php?topic=90556.0
If f/l think there's a how to in Maintenance guides :y
« Last Edit: 21 April 2013, 22:28:13 by dbug »
MV6Danny
« Reply #3 on: 22 April 2013, 10:31:53 »
Sorry its a 98 2.5td saloon
MV6Danny
« Reply #4 on: 22 April 2013, 10:35:54 »
That guide is for door card removal. I want to remove the outer plastic rubber trim below the windows on all 4 doors.  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #5 on: 22 April 2013, 11:10:16 »
Start at the back and work your way forward.
Can be a bit of a bitch to get back on properly.
I warmed mine up in the oven a little before re fitting  ;)
« Reply #6 on: 22 April 2013, 11:25:40 »
If your talking about the door to window seal they just lever out.Start from the rear iirc.The quarter panel trims also just lever out,but be careful as they are quite easy to break.
If you mean the bump strips half way up the doors - what Tiger said. ;)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #7 on: 22 April 2013, 12:35:54 »
Same principle with the rubber window seals Albs  ;)
A bit easier to get in the oven too  ;D ;D ;D
« Reply #8 on: 22 April 2013, 13:28:13 »
Didnt know that.I have one to fit soon,will do it at work.Got lots of oven there. :)
MV6Danny
« Reply #9 on: 22 April 2013, 16:44:19 »
Cheers give it a go at the weekend :y
Page created in 0.016 seconds with 14 queries.
