I wonder whats happened to my elite
Started by adey2, 23 April 2013, 09:28:36
adey2
Just been woke by missis to say a loud bang from engine bay the engine management light came on then cut out. She's currently sat on hard shoulder of m6 awaiting recovery and possible tow home.
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
pscocoa
Probably cam belt - same thing happened to me in 2008
adey2
nah it only 12 months old, shes just called the auxillary belt has snapped, but knowing my missis she wouldnt of noticed the battery light on saying a problem, just hope its not been cooked as rac guy said to her it was extreemly hot still when he got there
pscocoa
good luck with that - my son in laws Mondeo V6 had that happen last year - thought it might be cooked but was absolutely fine
Fingers crossed :y
The residual heat of the V6 is quite impressive ::)
zirk
Quote from: ex taxi al on 23 April 2013, 11:01:22
Fingers crossed :y
Good luck Al, my Ex stuffed my V6 HG within 5 mins of the aux belt coming off  :'(
adey2
its up and running but as rough as a bears ass, miss firing all over place, looks like lots of painstaking work ahead, only code it throwing up is hall sensor though
henryd
Quote from: adey2 on 23 April 2013, 11:44:28
Are you sure that none of the shredded belt found its way inside the cam belt covers,seen it happen and throw the timing a tooth or too ???
other rides
adey2
cover is unmarked, going to let it cool and check wiring to cam sensor, may of nipped it with flying debris
Happened to me with the first 3.0 , i was doing 70 ish on the motorway  ::) battery light came on but coasted it half a mile to the slip road with no power steering  :( Steam everywhere and aux belt wrapped around the tension er ... new belt and pulley wheel ... was fine after that  :y
adey2
still no joys, may take cam sensor off mv6 in min just to rule it out, thing is its so bloomin hot now
adey2
changed cam sensors over, no faults on mv6 with elite one fitted, going to go buy some new plugs just in case they broke down with heat, due a new set so wont harm, whilst changing them think i give compression test too
I'd be checking the cam timing before spending anymore money on it
sassanach
i ran mine for approx 8 miles with no water,result cooked!! head gasket time :'(
symes
hate to say it mate-but as 3.0 you likely need head gaskets doing-or worst case-another engine :'( :'(
