Author Topic: 2.2 Diff mounts  (Read 886 times)
Omegaclassic
2.2 Diff mounts
« on: 23 April 2013, 11:59:57 »
Hi peeps, was doing some work on back today when i notice that the rear drivers side diff mounting, the one which has bolts up into car and faces the back of the car has split a bit.Is this an mot failure theres no movement on diff. Are they easy to change looks like you just support diff undo both bolts and then renew mount then bolt back up.Is this right, thanks :y
Page created in 0.011 seconds with 14 queries.
