Author Topic: Cambelt fitting  (Read 4739 times)
Re: Cambelt fitting
« Reply #15 on: 23 April 2013, 14:47:21 »
Wasn't me ::)
Last change was at Guffers two years ago :-\ it was an absolute pig to time/tension iirc
Pm incoming Pete :y
Re: Cambelt fitting
« Reply #16 on: 23 April 2013, 15:08:18 »
Yep, DO NOT turn the crank if the drive to the cams is disconnected. It will be pistons hitting valves rather than compression that is your problem.
Turn the crank back by about 60 degrees from the TDC marking with the belt off. You should then have all of the pistons well down in the bores so it is then safe to turn each of the cams to the correct position for belt fitting and lock them using the kit.
Having locked the cams, rotate the crank forward by 60 degrees to the TDC position, lock it and fit the belt.
I find on the 3.2/2.6 without the adjusting lower idler, that if you rotate the crank about 1 tooth back before fitting the belt in an anticlockwise direction (i.e. over cams 4 and 3 first, then rotate the crank back to TDC before fitting the sprung tensioner, there is less likelihood that it ends up a tooth out.
You can always transpose the belt markings from the old belt to the new using some tip-ex. While not essential it does help.
Re: Cambelt fitting
« Reply #17 on: 23 April 2013, 15:13:56 »
Massive thank you to EP :y for reminding me to take the car out of gear :-[
Cams 3 and 4 were slightly advanced, but now spot on :y
Re: Cambelt fitting
« Reply #18 on: 23 April 2013, 15:16:35 »
Always a winner. :y
You sure you are up to this driver involvement lark? ;D
Re: Cambelt fitting
« Reply #19 on: 23 April 2013, 15:17:47 »
Is this the one that's always had that misfire, out of interest?
Re: Cambelt fitting
« Reply #20 on: 23 April 2013, 15:18:35 »
No adjustment on the lower idler :-\
No marks on the old belt either ::)
You can see where today is heading ;D
In answer to your next question... yup ::)
Re: Cambelt fitting
« Reply #21 on: 23 April 2013, 20:19:30 »
Finally sorted ::)
Mahoosive thank you to
Elite Pete for the phone support
Kevin for the technical support
Robsey for sorting the whole sorry mess when I screwed it up ::)
Re: Cambelt fitting
« Reply #22 on: 24 April 2013, 07:08:44 »
Finally sorted ::)
The main thing is you got it sorted :y
