Author Topic: Cambelt fitting  (Read 4741 times)
Cambelt fitting
« on: 23 April 2013, 13:00:39 »
Having watched the excellent OOF dvd 8) the time has come to fit the new cambelt...
Only one item of concern, the new belt has a couple of barcodes, but no other marks.
How do I align it on the crank pulley :-\
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Cambelt fitting
« Reply #1 on: 23 April 2013, 13:03:45 »
If the locking kit is in place it doesn't matter about the marks on the belt:y
« Last Edit: 23 April 2013, 13:05:55 by henryd »
other rides
Re: Cambelt fitting
« Reply #2 on: 23 April 2013, 13:04:34 »
What henry says!  ;)  ;)  ;)
JesperKjeldsen
  • Denmark
  • www.hingeauto.dk www.bestmufflers.com
    • Omega b 2,5v6 1994
Re: Cambelt fitting
« Reply #3 on: 23 April 2013, 13:07:05 »
look up a bit and see what henry wrote..  :y
Kjeldsen Out.
JesperKjeldsen
  • Denmark
Re: Cambelt fitting
« Reply #4 on: 23 April 2013, 13:09:54 »
https://www.dropbox.com/s/4eekzcri38u0vuc/E-Tech%20Reparaturleitfaden%20Omega%20B%2094-99.pdf
sorry its not in english.
please let me know if the link works, trying to get the entire repair manual up.
Kjeldsen Out.
Re: Cambelt fitting
« Reply #5 on: 23 April 2013, 13:10:13 »
Cheers lads :y
So basically:
Fit the belt
Adjust idlers
Tension
Rotate crank a couple of times
Check timing adjusting where necessary
Re tension
Rotate crank twice
Recheck
JesperKjeldsen
  • Denmark
Re: Cambelt fitting
« Reply #6 on: 23 April 2013, 13:12:00 »
nemlig det er lige sådan man skal gøre det..
or just. yeps that how to do it  :D
Kjeldsen Out.
Re: Cambelt fitting
« Reply #7 on: 23 April 2013, 13:16:08 »
Here goes...
Re: Cambelt fitting
« Reply #8 on: 23 April 2013, 14:06:57 »
All the best Al! :y :y :y
I have still got mine to do after promising myself to do it for months now.  Pushing my luck I know, but I am awaiting some cash to come through to afford it. ::) ::) ;)
Re: Cambelt fitting
« Reply #9 on: 23 April 2013, 14:24:37 »
Hit a snag
Timing marks were 180° out, managed to turn the crank 3/4 of a turn but it keeps slipping back when I try to move the ratchet back to turn it further. Engine is also very tight :-\
JesperKjeldsen
  • Denmark
Re: Cambelt fitting
« Reply #10 on: 23 April 2013, 14:27:01 »
its the compretion you can feel. turn the crank til you cant turn it no more and hold it there for a bit, it should help a bit
Kjeldsen Out.
Re: Cambelt fitting
« Reply #11 on: 23 April 2013, 14:33:01 »
:y shall give that a try
Re: Cambelt fitting
« Reply #12 on: 23 April 2013, 14:38:33 »
Don't force anything, you could bend valves.
Re: Cambelt fitting
« Reply #13 on: 23 April 2013, 14:39:10 »
Hit a snag
How did you manage that?
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Cambelt fitting
« Reply #14 on: 23 April 2013, 14:44:43 »
Should you not be rotating the crank until the timing on the cams nearly line up, before fitting the lock?
Sounds like the crank has been locked too early maybe?
Page created in 0.319 seconds with 16 queries.
