vec b 2.2 dti glowplug change issue
Started by mcd840, 23 April 2013, 16:47:31
mcd840
had my glowplugs changed today (wished youd never bloody touched something!), 3 of them come out no bother, the 1st one was left in as it just kept turning in the hole, it has made a huge difference just with the 3 of them re-newed, i was happy to leave it like this but now the management light is coming on and i susspect its due to a snapped plug, what options is there to remove this without removing head, i would rather they were all working as they should anyway, i know of a vec the exact same, all 3 come out no bother except for that first one.
cheers
It's a common problem and will need the head removing to sort :'(
henryd
other rides
Quote from: henryd on 24 April 2013, 17:41:28
Quote from: serek on 24 April 2013, 16:15:33
Quote from: Elite Pete on 23 April 2013, 16:54:04
if you have right tools then dont need take head off
EDIT:
http://www.ebay.co.uk/itm/New-Must-Have-Glow-Plug-Removal-Tool-Kit-Difficult-OR-Damaged-Plugs-/360515365866?pt=UK_Hand_Tools_Equipment&hash=item53f063ebea#ht_2098wt_957
Handy bit of kit that :y
It does look good but I would want to be sure its of good quality, wouldn't want the grief of trying to remove a snapped bit from the glow plug hole ::)
henryd
Quote from: Elite Pete on 24 April 2013, 17:45:55
EDIT:
very true,proper pain in the arris when that happens :-X
other rides
mcd840
im starting to think EML yesterday was just a coincidence as i havent seen it today and just had about a 70 mile run earlier, spoke to a vaux technician earlier who highly recomended an engineer up in perth, 30 miles up the road from me, went to see him after work, showed him the job and he would be more than happy to carry out the removal procedure and refit new plug for me (without removing head) second nature to him apparently as hes done it for years, he was kind enough to talk me through the procedure and showing me broken plugs he has removed over the years, ferrari use him aswell so i think i would be confident enough letting him do it, he also added wait and see if it gives you any trouble first as the warmer weathers starting and it will be fine on 3 plugs, allthough would be beneficial having the 4 of them working when winter arrives.
As a tip, remove glow plugs with the engine HOT.
Its also worth using a good penetrating fluid (e.g. NOT WD40 which is not even as good as human piss as a penetrant).
serek
EDIT:
if you dont try you wont know  :P
serek
Quote from: Marks Hornby 'OO' on 25 April 2013, 09:47:02
I use torque wrench set up at 30 NM when undo them so I know if this will be an easy job or drill out
mcd840
i will most likely get the broken one drilled out and when fixed i will not touch the buggers again!  ;D
