Author Topic: no heat from heater  (Read 2150 times)
paul.lovejoy
  • Ramsgate Kent
    • wife mad 2.6 cd estate
no heat from heater
« on: 23 April 2013, 21:35:39 »
Hi chaps the heater in the miggy only works if you have it on full blast and then its not that hot.
the temp gauge has also dropped to about 1/4 now
could this be thermostat or heater matrix perhaps
its a 2,6
a/c has never really worked assume seperate problem
Re: no heat from heater
« Reply #1 on: 23 April 2013, 21:46:14 »
its a 2,6
Probably thermostat ... to test (very easy this :) )
Start engine from cold - overnight preferably
Allow to idle whilst standing with one hand on the large pipe that goes from the thermostat to the radiator.
What SHOULD happen is the pipe remains cold until a sudden surge of heat as the thermostat opens
What MIGHT happen is the temperature rises slowly and continuously - because the thermostat has failed and is stuck open ...
That's the easy bit ...
To fix .....  change thermostat  :)
paul.lovejoy
  • Ramsgate Kent
« Reply #2 on: 24 April 2013, 07:56:10 »
merci monsuer i will try that today :y
skyblue
  • Bracknell
« Reply #3 on: 24 April 2013, 09:44:22 »
Dont forget, that you will need new  ( or cut the old ones down ) thermostate bolts.... caused me no end of trouble until this was pointed out to me. ;)
fastandy36
  • Corby, Northants.
  • First-Time Omega owner.01 Elite Model. What a car
    • omega 2.5 V6 Elite
« Reply #4 on: 24 April 2013, 10:24:16 »
cant see it being anything other than the 'stat
'Fasty'
