Author Topic: Bulb type/part number  (Read 4035 times)
horsecow
  • Omagh
    • 2.2 dti cdx/3.2 elite
« on: 26 April 2013, 12:20:27 »
As stated in a previous thread one of my headlight bulbs has blown. I don't know what type of bulb it is or what I'm after so was wondering of someone could tell me or let me have a part number so I can get a replacement before I start. It's an 03 2.6 cd and its the outermost of the 3 bulbs. Also what are the best bulbs to use? Many thanks guys
Drive 'er like yer late for mass!!
Re: Bulb type/part number
« Reply #1 on: 26 April 2013, 14:05:35 »
How's this? http://www.omegaowners.com/forum/index.php?topic=90457.0  :y
You say, the 'outermost' .... is that the dipped beam? Do you have HIDs?
horsecow
  • Omagh
« Reply #2 on: 26 April 2013, 14:11:10 »
TBH I haven't a clue what type of lights they are andy. There's 3 bulbs in the unit and it lights up  ;D. Its only the dipped headlight that  have failed on one side. I intend to go out and look but its absolutely lashing down here  >:( :'(
andyc
  • Norfolk
« Reply #3 on: 26 April 2013, 14:50:20 »
Should be an H1 bulb. GM part number is 93190463 @ £3.66 + VAT. If you go to any factor just as for a 55 watt  H1 bulb
Cheers
Andy
Thetford. Norfolk
horsecow
  • Omagh
« Reply #4 on: 26 April 2013, 16:21:37 »
Cheers guys, got a break in the rain there and popped it out and it is 55w H1as suggested. Is 55w the brightest available for dips as I always thought the dips were fairly dull, full beam are fantastic and the headlight covers are really clean, like new in fact, so no probs there but dipped heads do seem dull even when both were working. Maybe these are just cheap pattern bulbs
« Reply #5 on: 26 April 2013, 16:23:19 »
Is 55w the brightest available for dips as  .....
Legally for road use ....... yes!  ;)  ;)  ;)
horsecow
  • Omagh
« Reply #6 on: 26 April 2013, 16:35:14 »
Hmmmmm, so what are my other options then?? Is there any point going for any of these ice blue or purple or whatever other colour options I see advertised. Will they do any good?
« Reply #7 on: 26 April 2013, 16:37:44 »
NO
Silly colours are a result of playing with the colour "temperature", and have little link to increased light output, and in most cases actually REDUCE the "luminescence". Stick with 4500K, perhaps 6000K at most .. above that .. forget it... IMHO
« Reply #8 on: 26 April 2013, 21:27:11 »
Quite a few people seem to recommend Osram Nightbreakers as a good 'upgrade' - rated the same but better output.
« Reply #9 on: 26 April 2013, 21:39:00 »
+1 :y :y
« Reply #10 on: 26 April 2013, 21:41:23 »
+1 :y :y
Got them here in my 2.2, considerable improvement over standard  :y
Also worth keeping headlights clean, often before a night drive just give them a quick wipe as they easily build up a film of cr@p  :)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #11 on: 26 April 2013, 21:42:18 »
Have them on mine dip and main beam not as good as Xenon but about the best bulbs you can get for halogen headlamps.  :y
horsecow
  • Omagh
« Reply #12 on: 26 April 2013, 21:45:35 »
Have seen the ''nightbreaker'' named in a few threads and tbh I think I'll give those a try. Is it possible to fit Xenons in my lights?
« Last Edit: 26 April 2013, 21:52:12 by horsecow »
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #13 on: 26 April 2013, 22:02:22 »
I'm sure Sam Burton fitted them to his 2.2 Dti GLS / Elite conversion  :-\
http://www.omegaowners.com/forum/index.php?topic=102520.msg1284688#msg1284688 ;)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #14 on: 26 April 2013, 22:03:28 »
I'd check the new MOT regs before you think of doing a conversion.
TuBy's new whipping boy.
