Author Topic: Still misfiring  (Read 1892 times)
omegod
  • liverpool
    • 2017 Seat Ateca
Still misfiring
« on: 27 April 2013, 09:15:41 »
My 2.6 has had new plugs and a pair of known good coil packs fitted but is still running like shit, codes for misfire on cylinders 1+2 and p0300 :'(
Any suggestions people????
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Still misfiring
« Reply #1 on: 27 April 2013, 17:15:49 »
Anyone????
ECU..Injectors..??
millwall
  • se london
  • no muff too tuff
    • accord type s
Re: Still misfiring
« Reply #2 on: 27 April 2013, 19:27:30 »
Have you checked and cleaned coil pack connectors  just thinking rule out something silly
  • Auckland
    • Mazda MPV
Re: Still misfiring
« Reply #3 on: 27 April 2013, 19:38:07 »
Start with the basics
- cambelt cover off & check that the cam timing is OK
- spark plugs out & do a compression test
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Still misfiring
« Reply #4 on: 27 April 2013, 22:57:09 »
I did notice the fuel pressure wasn't too good when doing the cam covers, with it being the front two cylinders i.e furthest away from the pump???. I have a spare filter so will throw that on in the morning just for the hell of it. Advice taken on board anyhow  :y
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Still misfiring
« Reply #5 on: 29 April 2013, 17:39:04 »
I need to add code p1300 to the mix, Empty fuel receptacle????? it has petrol in !!
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Still misfiring
« Reply #6 on: 29 April 2013, 20:53:32 »
is your fuel pump working ok?  :y
RIP Paul Lovejoy
symes
  • oxford
    • R reg 940 volvo
Re: Still misfiring
« Reply #7 on: 29 April 2013, 20:59:18 »
I reckon the seals on injectors are shot-I had that on my 2.5 on number 5 iirc and that through up misfire + misfire code ???
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Still misfiring
« Reply #8 on: 29 April 2013, 21:48:20 »
SORTED.....new fuel filter helped, replacement bellow on the bagpipe helped more as it was split, then I  spotted an open vac pipe from the lower vac reservoir so plugged this and it is firing on all six!!
looks like the hbv is leaking but thats easily sorted!
Dazzler
  • Haverhill, Suffolk
Re: Still misfiring
« Reply #9 on: 30 April 2013, 10:12:49 »
Result :y
Page created in 0.201 seconds with 16 queries.
