Author Topic: T/belt inspection?  (Read 1782 times)
omegod
  • liverpool
    • 2017 Seat Ateca
T/belt inspection?
« on: 28 April 2013, 14:50:00 »
I need to take a peep at my V6 cam belt timing, whats the easiest way without removing too much stuff??
Re: T/belt inspection?
« Reply #1 on: 28 April 2013, 14:51:26 »
No easy way, you don't state what engine. But if its one with longer plenum, that has to come off, bag pipes out, aux belt at least...
  • Auckland
    • Mazda MPV
« Reply #2 on: 28 April 2013, 14:59:06 »
+1
Cambelt cover is trapped behind aux belt tensioner and cable tray.
You will save time overall if you accept that the bagpipes are coming out (5 minutes work). Once they are out of the way another 5 minutes to remove aux belt, aux belt tensioner, cable tray and cam belt cover. :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 28 April 2013, 15:03:02 »
And once you've done all that, what are you actually going to do?
If the belt is really overdue a change there might be some visible damage. Might.
You might find that the belt tension/timing is wrong, but you will need the timing tools to check.
What I'm trying to say is once you've stripped it as far as the belt, you might as well just change the bloody thing!
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #4 on: 28 April 2013, 15:18:16 »
It's a 2.6 with the long plenum, reason for inspection is it has a misfire that has not been cured with plugs and coil packs so it has been  suggested it may have slipped a tooth or two. I have a couple of other things to try first but just gauging this for when/if I need to. If it is wonky it will be getting broken up as won't be worth spending more on.
« Reply #5 on: 28 April 2013, 15:34:20 »
Have you had the breather units off from the top of the plenum?  ???
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #6 on: 28 April 2013, 17:36:20 »
I have Lizzie, amazing amount of crap came out of the breather system but all back together ok
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #7 on: 28 April 2013, 17:39:48 »
I'm with Nick W on this. You get that far you may as well change it.
RIP Paul Lovejoy
« Reply #8 on: 28 April 2013, 17:51:07 »
Are you sure?  I had a misfire after I had done a full service and guess what; it was that silly 'top hat' rubber gasket that I had managed to dislodge / or it had broken up from the connection between the black plastic breather box and the plenum!  Without it the engine was running crap, but once I had replaced with new, it ran soooooo smooth! :D :D :y
Worth a check of all else fails. ;)
PS The outstanding clue to the problem was a loud sssssssssssssss from the top of the engine!
« Last Edit: 28 April 2013, 17:52:49 by Lizzie Zoom »
Page created in 0.029 seconds with 16 queries.
