Author Topic: Estate Rear Adjustable Tie-Bars  (Read 4102 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« on: 28 April 2013, 23:09:24 »
Is that what they are called?
I can't seem to find them anywhere?  Mine are seized solid, i'd like to get another pair so i can strip them down and copperslip them up so they are nice to adjust for the up & coming 4 wheel alignment....
P6UL K
  • Dartford, Kent
Re: Estate Rear Adjustable Tie-Bars
« Reply #2 on: 28 April 2013, 23:27:00 »
Cheers Rob!  8)
P6UL K
  • Dartford, Kent
« Reply #3 on: 30 May 2013, 20:39:32 »
Just needed to 'up' this thread - Does anyone online have one of these to hand?
I need the measurement of one of these tie-bars from end to end...
Cheers  :y
« Reply #4 on: 30 May 2013, 21:03:17 »
Are they different from the saloon ones ? If the same I can measure them for you.
P6UL K
  • Dartford, Kent
« Reply #5 on: 30 May 2013, 21:04:15 »
And your asking me!? ha ha!
« Reply #6 on: 30 May 2013, 21:07:10 »
Fair do,s. ;D
« Reply #7 on: 30 May 2013, 21:08:13 »
P6UL K
  • Dartford, Kent
« Reply #8 on: 30 May 2013, 21:09:19 »
Get measuring Alb!  :y
« Reply #9 on: 30 May 2013, 21:10:52 »
Its dark now.Remind me in the morning. ;D
P6UL K
  • Dartford, Kent
« Reply #10 on: 30 May 2013, 23:22:31 »
Will do! :D
« Reply #11 on: 31 May 2013, 00:24:27 »
Albs its morning - don't forget  ;D ;D ;D ;D ;D ;)
« Reply #12 on: 31 May 2013, 00:35:18 »
Just give me about 11 hours. :P ;D............and then remind me again. :y
« Reply #13 on: 31 May 2013, 00:47:15 »
 ::) ::) ;D ;D ;D ;D ;D ;)
« Reply #14 on: 31 May 2013, 10:02:42 »
Just had an attempt at measuring one on the car,without jacking the car up. ::) ;D..............Seems to be pretty close to 575mm long,but then again,they are adjustable,so........ ???
If you want to source a pair which aren't seized solid Paul ? I can have a go at taking a pair off a car at the weekend,if its dry.
If you want brand spankers,then Allgerman as in Robs link is probably the way to go. :y
