Author Topic: Interesting Video. . .  (Read 3033 times)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« on: 30 April 2013, 03:42:33 »
I came accross this interesting video, All I'd like to know is it that simple  ??? i'd be worried about using wet and dry in a visible area like the bonnet, bumper etc.. Incase it doesn't buff out  ;D and where can I buy that kit  :D
http://youtu.be/VNbEdCx8GqM
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Interesting Video. . .
« Reply #1 on: 30 April 2013, 15:55:21 »
Been looking cant seem to find this kit anywhere for sale  :-\
amba
  • Medway towns
    • German V6
« Reply #2 on: 30 April 2013, 16:08:48 »
Item number:190644894664
Bay of Fleas,mate :y
bigbadee
  • plymouth
  • sorry about the spelling
    • omega diesel 2003/2.2
« Reply #3 on: 30 April 2013, 16:11:38 »
seems a bit pricey to me £27.99 plus £5.00 p&p for what seems no more than g3 cutting compound?
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #4 on: 30 April 2013, 16:15:07 »
Is that what that past is then ?
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #5 on: 30 April 2013, 16:19:35 »
Thanks Bud  :y
Found another slightly cheaper item no: 261206807020
bigbadee
  • plymouth
« Reply #6 on: 30 April 2013, 16:21:07 »
IMHA ide try the old t cut and a good polish first maybe with a little clear lacor brushed in to the scratch
« Last Edit: 30 April 2013, 16:23:37 by bigbadee »
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #7 on: 30 April 2013, 16:33:44 »
The car I have in mind for this has panels of scratches  ;D
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #8 on: 30 April 2013, 17:35:49 »
Has anyone tried the methods as in the video with wet and dry and does it buff out with the scratch gone or worse ? :-\
« Reply #9 on: 30 April 2013, 21:12:30 »
Methods in the video are old and well proven methods.  Tried and tested :y :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #10 on: 30 April 2013, 21:28:45 »
Thought as much it looks like an old video, There must be a cheaper kit than the one's on eBay ?  :-\
« Reply #11 on: 30 April 2013, 23:21:21 »
agreed ..  :y    with one exception..  if your clear coat is a bit resistant (like scratch resistant type)  and if the application height a bit higher than the surface level when dried you must not sand it directly..  first cover the increased height area with some soft bondo say minimum 4x4 cms .. let it dry and than sand with 1500 or 200 using a bigger block size at least 5x10 cms... reason is when you apply even small pressure on the sand area the increased height will dent the metal surface..(I did this mistake several times)
ps: bondo thickness must be tiny (enough just to cover up) and dont cause you to spend too much time
« Last Edit: 30 April 2013, 23:23:28 by cem »
