Author Topic: Always check the way in front!  (Read 3904 times)
Re: Always check the way in front!
« Reply #15 on: 01 May 2013, 23:47:34 »
Trap points in this case
So they did there job then, by preventing it joining the main line, a bit drastic though?....... :-\ :-\
How else do you stop a train?
« Reply #16 on: 02 May 2013, 00:08:42 »
Emergency cord!  ::) ::)
« Reply #17 on: 02 May 2013, 02:18:02 »
So they did their job then, by preventing it joining the main line, a bit drastic though?....... :-\ :-\
Very effective, presumably that would have been a touch more dramatic had the train been going more quickly :-\
Are such systems still in use, or do we rely solely on electrickery and computers :-\
Might such points have prevented the Ladbrook Grove crash from happening  :-\
Oh, and that'll be a £150 fine for improper use Mr P ;D
« Last Edit: 02 May 2013, 02:19:40 by ex taxi al »
« Reply #18 on: 02 May 2013, 08:07:51 »
Trap points are still used as are catch points as they protect against un-manned runaways as well as 'errors'.
Ladbrook Grove was somewhat different although some changes to the points arrangement could have prevented it (e.g.flank protection)
I can confirm that the Loco has sustained some heavy damage which is more extensive and much more costly than the brake rigging and coupling.
« Reply #19 on: 02 May 2013, 12:15:20 »
Thanks for that :y Used the example as I knew someone on the InterCity involved :'(
Is it beyond repair? Twisted chassis or summat :-\
On balance probably cheaper than passenger fatalities, which presumably is why those points are fitted...
« Reply #20 on: 02 May 2013, 12:20:12 »
That does not surprise me.  They are heavy machines and do significant damage when bounced over onto the sleepers via the track chairs.  The track of course would also be damaged. The springs, roller bearings, wheel flanges, brake rigging would all suffer, and there is always a risk of cracking the frames.  :(
« Reply #21 on: 02 May 2013, 12:24:06 »
I am surprised that they used concrete sleepers following a trap point.
No roller bearings on this one Lizzie, I am sure I will get the low down at the weekend from the GCR crews.
« Reply #22 on: 02 May 2013, 12:32:27 »
Ah, thanks Mark :y :y :y.  Yes these were introduced prior to BR days, and it was the later Standard classes on which they were introduced, so plain white metalled bearings on these Class 2's. Even more damage possible then. :'( :'(
symes
  • oxford
    • R reg 940 volvo
« Reply #23 on: 02 May 2013, 12:40:11 »
either way the loco is going to cost a fair bit to fix :'( :'( what a shame that was-hope it will return soon-too few around now-those things really have a soul dont they
« Reply #24 on: 10 May 2013, 17:51:47 »
Any news yet on the damage done, if any, to 46521 Mark? ??? ???
paul.lovejoy
  • Ramsgate Kent
    • wife mad 2.6 cd estate
« Reply #25 on: 10 May 2013, 19:09:32 »
handbrake :D
« Reply #26 on: 10 May 2013, 20:15:48 »
Quite a bit more than initially thought.
« Reply #27 on: 11 May 2013, 14:40:01 »
Thanks Mark :y :y :y
Any details to be had? ;)
