Author Topic: coolent level warning and windscreen wash warning  (Read 3171 times)
snowball
  • middlesex
« on: 02 May 2013, 14:59:59 »
Hi
I have a vauxhall omega - 2003 - last week the coolent level warning came on same time as windscreen wash warning.
filled up the windscreen wash and still showing me the check sign and yet is full to the top
Same with the coolent level checked and it is on the line - disconnected the sensor from the coolent holder and it still shows check coolent level even though it was disconnected
Any ideas on what the problems may be
Re: coolent level warning and windscreen wash warning
« Reply #1 on: 02 May 2013, 15:03:48 »
Sounds like an issue with the display unit :-\
Any other check warnings?
Has the instrument cluster be removed recently, might be as simple as a loose plug :-\
snowball
  • middlesex
« Reply #2 on: 02 May 2013, 15:32:11 »
Hi
No havent had any works done on the car - apat from climate control panel a year ago
snowball
  • middlesex
« Reply #3 on: 02 May 2013, 15:33:09 »
Brake check but that always comes on when I start the car
« Reply #4 on: 02 May 2013, 15:45:57 »
That's normal :y
Might be coincidence that both sensors have failed together :-\ the wiring runs in different directions for each sensor...
If you open the coolant cap and look in, there should be a golf ball sized float directly under the cap. It should pop straight back up if you push it down :y
For the washer sensor, it might be worth popping the switch out of the washer bottle and check that the float moves freely :y
snowball
  • middlesex
« Reply #5 on: 02 May 2013, 17:54:22 »
Hi
I have opened the coolant bottle and the float is down at the bottom and doesnt spring up if you push it down
Re the windsceen wash - not sure where the float is - there is the tube where I pour in the windscreen wash where would the float be
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #6 on: 02 May 2013, 17:56:50 »
Hi
New expansion tank needed  :y
RIP Paul Lovejoy
symes
  • oxford
    • R reg 940 volvo
« Reply #7 on: 02 May 2013, 18:13:00 »
Hi
+1 :y
« Reply #8 on: 02 May 2013, 18:46:24 »
Hi
Circled green in pic. Couple here if one needed :)
« Reply #9 on: 02 May 2013, 18:47:47 »
 ...... and suddenly a shop keeper arrived with a picture!  :y :y :y :y
« Reply #10 on: 02 May 2013, 18:48:15 »
:P ;D
« Reply #11 on: 02 May 2013, 18:51:25 »
Expansion tank  90500223 £40
Looks a lot better as well :)
« Last Edit: 02 May 2013, 18:56:49 by RobG »
moggy
  • hartlepool
    • vauxhall omega 3.0 elite
« Reply #12 on: 02 May 2013, 20:14:08 »
Off topic,Rob you seem to have a picture of everything.Do you have a picture of kylie minogue,naked,pm to me if you do. ;D ;D ;D.BTW hope you are well Dean :) :y
Webby the Bear
  • Northampton
« Reply #13 on: 02 May 2013, 20:17:11 »
Word on the street is he has a few photos of TB's keyhole surgery aftermath...... and will be available in the OOF shop next week
RIP Paul Lovejoy
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #14 on: 02 May 2013, 20:23:05 »
My son has justed started to watch mr benn on ootube,brings back memorys
 51 festive road.
 off every one goes to watch :) ;)
Hoof'land storeman.
